RV.Net Open Roads Forum: Dinghy Towing: Charging a towed vehicle's battery
Search only in Dinghy Towing
 > Charging a towed vehicle's battery
fwtraveler1
Posted: 09/24/21 10:08am Link  |  Quote  |  Print  |  Notify Moderator
I can not get my RVI battery charger to work towing my 2020 Chev Equinox. Is there another/better system out there for charging a towed vehicle behind an RV?
obgraham
TriCites WA
Posted: 09/24/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
In the receptacle on the motorhome there is an "always hot" pin. At least there was on mine. I had them run a separate wire from that pin directly to the toad battery.
Quartzsite, AZ
Posted: 09/24/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Excellent suggestion IMO.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
CA Traveler
The Western States
Posted: 09/24/21 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
It could be defective, mis wired, inadequate wiring, no input from the MH. A voltmeter is your friend.
2014 Grand Cherokee Overland
Bob
jdc1
Rescue, Ca
Posted: 09/24/21 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Just toss a solar charger on the dash.
mowermech
Billings, MT
Posted: 09/25/21 05:51am Link  |  Quote  |  Print  |  Notify Moderator
THAT is the best idea! Yes, it will require a 7-pin plug on the toad, but that is easily doable. Be sure that "always hot" pin is wired with 10 gauge wire from the power source in the motorhome all the way to the toad battery, and be sure there is a 30 amp fuse or circuit breaker installed in the line at the motorhome power source. Higher amperage may be required.
CM1, USN (RET)
Daily Driver: '14 Subaru Outback
Toad: '05 Wrangler Unlimited
Toy: 1999 Dodge QC LWB, Cummins, Auto, 4X4
Other toys: 2 Kawasaki Brute Force 750 ATVs.
JRscooby
Indepmo
Posted: 09/25/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Not sure "always hot" is the best idea. I think a better idea was have the charge pin controlled by the ignition switch of MH. (If it ain't running, it won't charge anyway)
And the toad end can't be mounted solid, unless you use a removable cord. A switch near toad battery to disconnect would stop a hot wire from causing trouble when not towing.
bighatnohorse
Gig Harbor - Cave Creek
Posted: 09/25/21 07:54am Link  |  Quote  |  Print  |  Notify Moderator
I'm currently installing an Invisibrake system and I have run a charge wire from the truck battery to the tow'd.
The hot wire is fused at both the truck and tow vehicle batteries.
The hot wire is always hot.
obgraham
TriCites WA
Posted: 09/25/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Indeed, I mis-wrote in my post. The "always hot" pin was wired to the ignition-controlled circuitry on the MoHo. I don't really want it charging when the rig is shut down.
The MoHo had the 7-bladed plug, and I used an adaptor to go to the more typical 7-pin plug to connect the toad.
lryrob9301
Mid-Atlantic
Posted: 09/25/21 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
Are you pulling the fuse for the rear windshield wiper as per instructions?
"NOTE: Towed Battery Charger Plus is compatible with all 12 volt batteries including trailers. 2019-present Chevy Equinox must pull rear windshield wiper fuse."
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
