RV.Net Open Roads Forum: Travel Trailers: Over filling
Open Roads Forum  >  Travel Trailers  >  Small TT's
 > Over filling
Danford50
North Carolina
Posted: 09/24/21 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2016 coach Catalina I purchased it used our first trip when I connected my water hose to city fill and I went back later to check everything out I noticed that my fresh water tank was over filling out to the ground, I think it might be a check value not working, but this camper is new to me , where would I look for the check value.or maybe someone else has had this problem who can give me how to fix it.
Bumpyroad
Virginia
Posted: 09/24/21 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
you overfilled the tank and it spilled out. seems routine to me. did it somehow get switched to tank fill by mistake?
bumpy
CA Traveler
The Western States
Posted: 09/24/21 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
The tank has a vent in the top to let air in/out. When filling air and then water comes out the vent.
2014 Grand Cherokee Overland
Bob
routeforty
ohio
Posted: 09/24/21 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have a coachman a couple years newer than you and I have done this twice. One was while filling and not paying attention when it filled up. The other was when I thought I had my water switch on city but it was on tank fill while we took a walk around the CG. The water overflowed for at least 15 minutes. No problems except for a lot of water wasted and a muddy mess around the motorhome. The water just goes out the top vent or overflow and onto the ground.
2018 coachmen leprechaun class c
Bobbo
Wherever I park
Posted: 09/24/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
This is ambiguous. There is a city water inlet and a tank fill inlet. (Not all rigs have a separate tank fill inlet.) If you connected to the city water inlet, then you do, indeed, have a backflow preventer in the water pump that has failed. If you connected it to the tank fill inlet, you need to stand there while it fills till water comes out the inlet and vent, then turn the water off.
The units without a separate tank fill inlet have a valve that you turn to switch between city water and tank fill. If that valve is turned wrong, that will happen.
Bobbo and Lin
routeforty
ohio
Posted: 09/24/21 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Just reread your post-I answered a question you didn't ask. On mine, if yours is similar-has a switch or lever where the water fill is. this must be turned to what you want-whether city or tank fill. Mine is blue and about 2" long.
wanderingbob
monticeeo, fla
Posted: 09/25/21 06:16am Link  |  Quote  |  Print  |  Notify Moderator
Where was the water coming out ? I have never heard of " city fill " , are you sure that is what it sez ?
Robbies grandpa
Central Florida
Posted: 09/25/21 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Sounds to me like there is a check valve issue with your water pump. This happened to me once and I had to replace the pump.
rrupert
NW PA
Posted: 09/25/21 08:44am Link  |  Quote  |  Print  |  Notify Moderator
This is a common question asked on a Jayco Facebook group. Many times it is the pressure check valve on the pump especially if the pump hasn't been used for some time. The check valve gets dry and sticks. Pumping some water from the freshwater tank can help to prevent that. That check valve is located on the power input end of the pump.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
wnjj
Cornelius, Oregon
Posted: 09/25/21 09:02am Link  |  Quote  |  Print  |  Notify Moderator
^this
1. Run some water through the faucets using only the pump.
2. If that doesn’t fix it you may have to take the pump apart to clean a piece of debris out.
3. Failing that, you can usually buy a rebuild kit (new diaphragm) or new pump.
 > Over filling
