RV.Net Open Roads Forum: Tech Issues: Pairing honda eu generator problem
 > Pairing honda eu generator problem
Teeton
Northeast Pa
Posted: 09/24/21 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Got 2 honda eu2200 generators. When i pair them and plug in my camper (120v) to the 30amp serve it blows the camper main fuse. Now one eu2200 has 2 ,, 20 amp outlets and the other has 1,,20 amp outlet and one 30 amp outlet. Now im using a adapter to go from the 30 amp service to the 30 amp service on the camper. If i take the camper wire and plug it into the other generator with the two 20 amp outlets alls good. Yes the left and right cables and grounds are hooked up right.
agesilaus
North Florida
Posted: 09/24/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
You need on EU2200i (companion) and one EU2200 don't you?
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
enblethen
Moses Lake, WA
Posted: 09/24/21 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Adapter is a twist lock, Correct?
Tripping of the RV breaker would indicate a problem in the rig.
Does the rig work when using shore power to a commercial 30 amp receptacle?
Make and model of rig?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rlw999
Washington State
Posted: 09/24/21 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Is it really blowing a fuse or is it tripping the EMS? Did you try bonding the ground+neutral? Have you ever used that adapter before? Maybe it's miswired and tripping the EMS?
If it's really tripping a fuse or circuit breaker in the RV, I can't think of any reason for that, I'd measure the 30A output to make sure it's really 120V.
enblethen
Moses Lake, WA
Posted: 09/24/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Turn off all brnch breakers, then try it!
2oldman
NM
Posted: 09/24/21 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
No
agesilaus
North Florida
Posted: 09/24/21 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
No
No? That's interesting
Posted: 09/25/21 05:10am Link  |  Quote  |  Print  |  Notify Moderator
measure the voltage at the adapter's TT30 before you plug in the RV.
Also make sure you don't have too much turned on
Water heater
A/C
Microwave are all big load items. have ALL of them off. Turn their breakers off
Teeton
Northeast Pa
Posted: 09/25/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
First poor cell to no cell at camp ground. So my response time will be poor cuz I have to leave the campground. With the other 4000 old generator or just plugging it into a 20 amp house outlet with adapter it works fine. Alls off in camper. Yes its popping a breaker. I have adapter that goes into the 30 amp outlet that brings it down to a standard 20-amp plug plugging into that in pops. Pupping it into the othe generator with the 2 20amp outlets it work fine. I see nothing on the companion adapter cords to lock them in
2oldman
NM
Posted: 09/25/21 07:37am Link  |  Quote  |  Print  |  Notify Moderator
You can pair darn near anything in the Honda line.
