RV.Net Open Roads Forum: Tech Issues: No Shore power
 > No Shore power
flip418
Posted: 09/25/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
2015 Keystone Cougar 330RBK that will not power up with just shore power. I assume the inverter but I’m unable to locate! Help!!
The Thomas's
2012 Keystone Cougar 328QBS
2004 Ford F-250 PSD
Firestone Air-Rites
SAR Tracker
Central Oregon
Posted: 09/25/21 08:32am Link  |  Quote  |  Print  |  Notify Moderator
1. - Is there power at the pedestal (or wall plug)?
2. - Breakers?
3. - Inverter changes battery power to 120volts.
4. - Is converter (battery charger) running?
5. - Does Microwave or any of the outlets operate?
6. - is the red button on the GFCI (usually in the bathroom) sticking out?
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
BB_TX
McKinney, Texas
Posted: 09/25/21 08:47am Link  |  Quote  |  Print  |  Notify Moderator
You need to verify power is actually getting to the trailer. The pedestal, your power cord, your internal breaker, etc. Voltmeter is a necessity.
Does anything 120 vac work inside the trailer?
Do you have generator prep with a transfer switch? Those transfer switches are a known problem.
jdc1
Rescue, Ca
Posted: 09/25/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Or, just maybe, your battery disconnect switch was inadvertently turned off? That would be for the 12V side.
Posted: 09/25/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Need more bread crumbs OP….
2017 Heartland Torque T29
flip418
Posted: 09/25/21 09:55am Link  |  Quote  |  Print  |  Notify Moderator
There was power from pedestal and microwave had power. The new battery did not seem to charge and I had to have a battery charger on it all week. Cannot tell if inverter was running because I can’t locate. I checked all possible breakers and fuses that I can find.
flip418
Posted: 09/25/21 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Where would converter be located?
enblethen
Moses Lake, WA
Posted: 09/25/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Converter are qite often located adjacent, in back of, 12o volt power distribution panel.
Does any of the 120 volt items work? receptacles?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
flip418
Posted: 09/25/21 10:24am Link  |  Quote  |  Print  |  Notify Moderator
All receptacles work…I’m thinking an in-line fuse that charges battery from pedestal? We were hooked up to 50 amp but after a few days we had no lights because battery was dead. I know the lights are 12 volt…we had microwave at the time but no fridge
bgum
South Louisiana
Posted: 09/25/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Let's get our terms down.
The converter charges your battery and converts 120 volts to 12v.
A inverter takes 12v and boost it to 120 volts.
 > No Shore power
