RV.Net Open Roads Forum: General RVing Issues: flex seal
 > flex seal
thoms
tampa, fl.
Posted: 09/25/21 09:58am Link  |  Quote  |  Print  |  Notify Moderator
hi all, just wondering if you can use flex seal on camper roof to seal around plastic dome over shower. I have a 2011 jayco jayflite tt. do not want to replace cover now. will this winter. have extra can of flex and do not to waste it. Any thoughts.
Thanks
sorry for posting this, just read another post on same subject, my bad
* This post was edited 09/25/21 10:17am by thoms *
Mel Stuplich
Wausau, WI
Posted: 09/25/21 10:52am Link  |  Quote  |  Print  |  Notify Moderator
You can but Eternabond tape would be better.
MitchF150
Puyallup, WA
Posted: 09/25/21 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
I think it's fine for a temp fix or road side repair. I carry a couple of cans with me on my adventures, just in case...
I've heard good things about the 'tape' they have too.. I've not personally used it, but again, a quick fix just like a spare tire..
I have used the spray on other things and seems to work and sealed what it needed to seal until I could fix it. Outdoor shed roof leak..
Good luck.. Mitch
shannon62
Pennsylvania
Posted: 09/25/21 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
You betcha, it is good stuff.
jdc1
Rescue, Ca
Posted: 09/25/21 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
The question should include "Will Dicor or Heng's roof products stick to Flex Seal?" Think ahead. If you go to recoat your roof next year, you find it difficult stripping off that Flex ****.
mobeewan
Hampton, Va
Posted: 09/26/21 12:45am Link  |  Quote  |  Print  |  Notify Moderator
I bought a can of clear Flex Seal to spray the outside surface of my skylight until I can replace it. It was cracking and leaking due to sun damage. Tape it off so you can spray the plastic only. Use self leveling Dicor around the edges.
 > flex seal
