RV.Net Open Roads Forum: Fifth-Wheels: Generators for 5er
 > Generators for 5er
dogvetia
papillion, nebraska
Posted: 09/25/21 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
After 35 years in motorhomes with on board diesel generators, we are downsizing to a 32 foot fiver. Have a ton diesel to pull so that should not be an issue. Issue will be generating enough juice to power both airs and a couple of frig wine cooler.. want something quiet since we dry camp some.. is a generator mounted on a rear rack or one carried in pick up bed better? Is a single 7000 Honda better than 2 smaller generators hooked together to provide adequate power better? I would theft maybe issue on rear rack mounting. Ant advice from experience would be appreciated. I fear the move won't be pain free but to look on it as a challenge. Thanks
2012 F350 diesel
2018 cruiser lite 28rd
jdc1
Rescue, Ca
Posted: 09/25/21 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Two 15k AC'c, a converter, maybe an inverter for the fridge? Add it up. Sounds like you are in the market for a Honda EU7000is....about $4500+.
bgum
South Louisiana
Posted: 09/25/21 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
I would go with 2 Westinghouse i4500 with a 50 amp parallel cord. We have two of their i2500 and they are strong and quiet with good fuel mileage. Two i4500 will provide all the juice you need and at times you will want to run only one. Our Westinghouse has been very reliable. They cost less than $900 per.
pianotuna
Regina, SK, Canada
Posted: 09/25/21 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Bgum,
Does the Westinghouse i4500 have remote electric start?
Regards, Don
Pipeman
Windsor, Ontario,
Posted: 09/26/21 04:52am Link  |  Quote  |  Print  |  Notify Moderator
Pianotuna I just googled it and it says it has wireless remote start.
Pipeman
Ontario, Canada
35 year Fire Fighter(retired)
VE3PJF
bgum
South Louisiana
Posted: 09/26/21 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Electric and remote start. They also have a dual fuel for $1100.
Near DVNP, California
A generator carried on a rear rack needs substantial reenforcement.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
mhardin
Texas!
Posted: 09/26/21 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
I cannot imagine trying to run two 4500 Watt generators on Propane unless connected to a bulk tank too big to be hauling around in a pickup and 5er. They would blow through a 20 pound bottle in no time.
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
n0arp
FT
Posted: 09/26/21 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
I recommend considering an Onan 5500 onboard generator if you have the space for one. That will power both air units, a residential fridge, and have plenty to spare even at elevation.
Our fifth wheel when it was configured with 2x Dometic 15K AC units, a residential fridge, and a lot of miscellaneous electronics would consume 2700W with both AC units running full force and fridge on defrost. We could start both AC units with the Onan no problem, without soft starts. You don't need a 7kW generator. Depending on where you camp (altitude) and whether or not you have soft starts, a single 4500W would likely suffice.
* This post was last edited 09/26/21 03:49pm by n0arp *   View edit history
2021 Ram 5500 Limited 84CA Cummins 4x4 w/ flatbed
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
bgum
South Louisiana
Posted: 09/26/21 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
We owned a Onan powered by propane in our 5th wheel. It could eat through a lot of propane. My choice for portable generators is gas and for home generators is natural gas.
