RV.Net Open Roads Forum: Fifth-Wheels: Generators for 5er
 > Generators for 5er
Rigdon
Anywhere there are roads.
Posted: 09/26/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
unless the rear cargo carrier is extremely built and the trailer frame reinforced it will not be capable of carrying the weight of a 7000 watt gen.
Steve & Karen
theoldwizard1
SE MI
Posted: 09/26/21 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
bgum wrote:
I would go with 2 Westinghouse i4500 with a 50 amp parallel cord. We have two of their i2500 and they are strong and quiet with good fuel mileage. Two i4500 will provide all the juice you need and at times you will want to run only one.
You can get 50A out of two iGen4500 but only at 120V ! That means only ONE A/C unit !
If you are willing to have an electrician do some wiring, you can change you 50A plug to two 30A plugs. You will need a second breaker panel installed and you won't be able to run any 240V appliances.
Cummins12V98
on the road
Posted: 09/26/21 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
bgum wrote:
We owned a Onan powered by propane in our 5th wheel. It could eat through a lot of propane. My choice for portable generators is gas and for home generators is natural gas.
I have a Cummins 6500 Commercial 220V. It is Very thirsty. Should have gone Diesel.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
edatlanta
Maplesville, AL Home Base
Posted: 09/27/21 03:47am Link  |  Quote  |  Print  |  Notify Moderator
I have the Onan 5500 that was factory installed with a 10 gallon gasoline tank built in also. I don't think RV manufacturers offer the gasoline option now but not sure. I do know my gas 5500 works great, runs both a/c's and everything else I use at the same time and runs a bit north of 20 hours on 10 gallons depending load. 11 years full time use, 650 hrs on the Onan and not looking back.
I do use non-ethanol gas and still put stabilizer in every tank plus running the generator every month for 1 hour under load.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
gtnsmlr
On the road
Posted: 09/27/21 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
I carry a 6.5 kw Honda in the back of the truck in an all weather enclosure, installed a remote start and it runs everything just fine. Only drawback ,if you're boondocking in 100+ weather you'll be going thru 4-8 gallons a day running ACs, we stay mostly in state parks and most of those have 50A power. In 4 years fulltiming we put about 600 hrs on it and have never regretted the purchase.
The older we get, the faster we go
Bionic Man
Colorado
Posted: 09/27/21 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
I have a built in Honda 6010 that runs on propane. As others have said, it is very thirsty. But it is secure, reliable, and incredibly convent. I also have a Yamaha 2000 that I carry when I just need to charge batteries (yes, I know I should go solar).
We also have a 7000 Honda that we use on our houseboat. That generator is awesome. Much quieter than either the 3500's, or the 2000 that I have. But it is also a tank. I can't imagine trying to maneuver it by hand.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
wantabe351
Parsippany,NJ
Posted: 09/30/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
I put a 5k Gen in our front cargo space and also ran a fuel line with a marine outboard fuel connector down and out the front part of the front cargo space, I bought a 7gal portable marine fuel tank and between the tank connector and the Gen fuel connector I made a 6' fuel line with the female ends.... So weather driving or stationary I could run the Gen and AC units....This would cooldown the RV when we pulled into or camp site, especially nice in HHH weather..A 5k Gen could run both AC units with no problem...
Rich & Andrea
05 dodge 3500HD DRW quadcab,ctd610,auto,4:10,Tow pkg,susp-upgraded+airbags,Smarty module,Water/Meth injection,2ndfueltank,gauges.
2011Montana 3400rl,5kGen,4-6v,inverter,W/D,solarpower,
MikeRP
Westerville
Posted: 10/02/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I recommend you just go with one generator. I just have a predator 3500 that is very quiet and handles my needs. I use only gasoline. For $650 it’s worthwhile to try then you can sell it and not lose much if you want to move up.
If I decide I need more later, I still will not have two,
Veebyes
Posted: 10/02/21 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
What is the fixation with high KW gennys? At home in Bermuda I have a portable 3.5KW genny as backup for hurricanes.
It has been needed a number of times. It runs the house just fine which includes two water heaters & a shallow well pump, two fridges, plus all of the small stuff. Cooking is propane. No heat. No air.
2007 Alpenlite 34RLR
Lantley
Ellicott City, Maryland
Posted: 10/02/21 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Veebyes wrote:
What is the fixation with high KW gennys? No heat. No air.
When it come to higher KW gensetsTHe fixation is the A/C.
If no A/C is involved any 2000 watt unit will do. But A/C is a real concern that requires more power. Sleeping/living in a hot RV is not an enjoyable experience
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
