laknox
Arizona
n0arp wrote: I recommend considering an Onan 5500 onboard generator if you have the space for one. That will power both air units, a residential fridge, and have plenty to spare even at elevation.
Our fifth wheel when it was configured with 2x Dometic 15K AC units, a residential fridge, and a lot of miscellaneous electronics would consume 2700W with both AC units running full force and fridge on defrost. We could start both AC units with the Onan no problem, without soft starts. You don't need a 7kW generator. Depending on where you camp (altitude) and whether or not you have soft starts, a single 4500W would likely suffice.
Thing is, the Onan gensets are constant speed, wide open, all the time, even when load is not demanded. Personally, I'd opt for the biggest inverter I could get and build up a beefy rear rack with a "gen box" to contain the generator, 50a plug and transfer switch. I saw one that had a built-in 20gal fuel tank, too.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
laknox
Arizona
Lantley wrote: Veebyes wrote: What is the fixation with high KW gennys? No heat. No air.
When it come to higher KW gensetsTHe fixation is the A/C.
If no A/C is involved any 2000 watt unit will do. But A/C is a real concern that requires more power. Sleeping/living in a hot RV is not an enjoyable experience
Correct! "If mama ain't happy; ain't NOBODY happy!" :-)
Lyle
pyoung47
MO
Champion has a new 4500 watt plus line which offers electric and remote start. If you are going to be off grid, I would "tough it" with one AC requiring only about 3500 watts. Carrying two 4500 watt units would be overkill --
PhilipB
MO
Prior to our toy hauler we had a regular 5er and a Yamaha 3000 in the bed of the truck. We ran generator in the bed of the truck, but would unhook from camper when doing this. It worked well, but required having portable gas cans.
Toy hauler has 5500 Onan. We have 60 gallons of onboard fuel which is great. No unhooking, no cords, no gas cans. No overload worries. It does drink more fuel.
You might search for a diesel generator you could mount in truck bed and feed off the truck.
2015 Ram 2500
2013 Raptor 310TS
laknox
Arizona
PhilipB wrote: Prior to our toy hauler we had a regular 5er and a Yamaha 3000 in the bed of the truck. We ran generator in the bed of the truck, but would unhook from camper when doing this. It worked well, but required having portable gas cans.
For the life of me, I can not figure out why Onan hasn't started making inverter gensets OR why Honda dropped their on-board gensets years ago OR why Champion, or any other company, hasn't started building on-board inverter gensets. ![scratchead [emoticon]](http://www.rv.net/sharedcontent/cfb/images/scratchead.gif)
Lyle
Lantley
Ellicott City, Maryland
laknox wrote: PhilipB wrote: Prior to our toy hauler we had a regular 5er and a Yamaha 3000 in the bed of the truck. We ran generator in the bed of the truck, but would unhook from camper when doing this. It worked well, but required having portable gas cans.
Lyle
There really 2 different markets. A built in Onan is a $7000.00 option.
vs. any portable which are 1/3-1/2 the price with none of the conveniences of a built in.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Cummins12V98
on the road
Mine is a Commercial 6500 LP 220V Cummins/Onan and it's very thirsty. Anyone done a change over to gasoline on one of these?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
n0arp
FT
I changed a 5500LP over to gas. They have diagrams for everything and I just pulled up the diagrams for both the LP and gas models, and ordered everything that was different. It ended up being just the carb and some regulator, I believe, but that was a few years ago. I used a 12V fuel pump off Amazon and an 18gal marine fuel tank. I swapped it back over to LP at some point because I decided I'd rather have the space the gas tank was taking up for batteries.
edited 10/15/21 01:26pm by an administrator/moderator *
laknox
Arizona
Lantley wrote: laknox wrote: PhilipB wrote: Prior to our toy hauler we had a regular 5er and a Yamaha 3000 in the bed of the truck. We ran generator in the bed of the truck, but would unhook from camper when doing this. It worked well, but required having portable gas cans.
Lyle
I'd be willing to bet that a goodly portion of that price is simply the "Onan" badge. It'd likely be the same, or more if it were Honda. Again, why doesn't Onan build an inverter genset?
Lyle
n0arp
FT
laknox wrote: Again, why doesn't Onan build an inverter genset?
Lyle
They do. The only one so far for "RV Use" though is the QG2800i (and 2500i version for LP). Released Jan/21. Larger ones should be coming soon.
