RV.Net Open Roads Forum: Aqua Hot 450D troubleshooting cool air zone 2 (front)
 > Aqua Hot 450D troubleshooting cool air zone 2 (front)
#Marc
Waterloo , Ontario , Canada
Posted: 09/26/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
Allegro Bus 45LP 2014 Aqua hot 450D
Aqua Hot cool air zone 2 (front)
1- All light are green
2- Plastic container at right level of anti-freeze when hot or cold.
3- Tap the check valve
4- Pump is working I can it hear running.
5- Check line zone 1 and zone 2 both hot from the check valve to Pump
6-Check both line after the pump and up pass the aqua hot housing both hot.(Note[emoticon]aybe the zone 1 'line is a tiny bit hotter than line 2)
7- Check all the line for king or leak (nothing found)
8- try to push antifreeze thru the system with a manual pump kit It worked but overfill plastic container.
8- Left it run for about one hour
I did # 8 thinking that I have a airlock and also did unscrew the top valve to let air out.
This is where I am not 100% sure how to get rid of an air lock (or pressurize the system). What would be the exact procedure step by step ?
What Am I missing? , everything seems to work fine but still no heat zone 2 (front)
Marc & Josée
Tiffin Allegro Bus 45LP
450 HP Cummins ISL
MountainAir05
New Mexico
Posted: 09/26/21 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
#3 that you are tapping is the check valve cold right, if so rap it harder, they can get stuck. Post back.
I assume that you took the cover off to tap the valve while the unit is running.
* This post was edited 09/26/21 03:34pm by MountainAir05 *
Trainer
Livingston, TX, USA
Posted: 09/27/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Using your manual pump, attach the return pipe for that zone to the intake of pump. Attach output of pump to return fitting on rear of tank. Turn on manual pump and Aqua Hot zone pump. That should purge air in heating loop.
I have done this when installing a new heater in a Alegro Bus whose owner allowed the fresh water loop to freeze and split necessitating the new heater.
folivier
Southeast Louisiana
Posted: 09/27/21 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Does this have the clear cube relays like the older model? If so pull them and reseat them. They sometimes get loose.
Trainer
Livingston, TX, USA
Posted: 09/27/21 06:56am Link  |  Quote  |  Print  |  Notify Moderator
The 450D is run by an electronic control board, no clear relays.
The 450D has a 5 gallon coolant tank where the older heaters you mention have a 16 gallon coolant tank.
dougrainer
Carrolton, Texas
Posted: 09/27/21 09:52am Link  |  Quote  |  Print  |  Notify Moderator
You have 3 pumps. It is very hard to "hear" a pump running. I usually put my hand on the pump to feel if it is running. I also feel the return lines coming in the top of the Aqua Hot and the lines should be as hot as the lines coming out of the pumps. I am not sure from your post if you did that. IF the return lines are all hot, then the coolant IS flowing thru the radiators. Do the radiator muffin fans come on? Are you using the Diesel burner to get the tank hot? Doug
C20
Shawnee KS
Posted: 09/27/21 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Trainer is the man on these. He hooked me up last winter.
2015 Monaco Dynasty
97 jeep wrangler
16 HD CVO Street glide
2015 Challenger Hellcat
2020 ram 2500 Cummins
dougrainer
Carrolton, Texas
Posted: 09/28/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Yes, and his post did not ask questions. The OP has also not responded to questions. Doug
#Marc
Posted: 09/28/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Yes tap it when cold and hot. No luck.
I am clueless about what could be the problem????
I taught I could save myself a trip to the dealer.
MountainAir05
New Mexico
Posted: 09/28/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
So are all the pumps running when you touch them.
