RV.Net Open Roads Forum: General RVing Issues: toilet
pushtoy 2
texas
Posted: 09/27/21 08:20am Link  |  Quote  |  Print  |  Notify Moderator
i am new to this site hello all. hope someone can help me with is . i have put 3 new flush seeles in my toilet the last a little while dont understand what is happening the start leaking again the bowl stops holding water. i have put plumbers grease on it and that doesnt last eather. can anyone help.
DREAMER ">
jdc1
Rescue, Ca
Posted: 09/27/21 08:35am Link  |  Quote  |  Print  |  Notify Moderator
There is a rubber seal that needs to be replaced. YouTube is you friend here.
pushtoy 2
texas
Posted: 09/27/21 08:46am Link  |  Quote  |  Print  |  Notify Moderator
i have replaced that seal 3 times and it is leaking again. the utube video was a great help and the instructions that came with the seals iwas hoping some one would have a fix for it.
enblethen
Moses Lake, WA
Posted: 09/27/21 10:01am Link  |  Quote  |  Print  |  Notify Moderator
Most of the problems are debris in the seal and not the seal it self.
Thetford makes a tool called "bent screw driver" to clean it.
Cause of debris is sometimes linked to miss use. Too much toilet paper!
Make and model of toilet?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Posted: 09/27/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Facepalm....
2017 Heartland Torque T29
HappyKayakers
Somewhere in the USA
Posted: 09/27/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
2 suggestions. First, open the flush valve all the way and rotate a toilet bowl brush thoroughly in the opening. If that doesn't work, the next time the ball valve is dry, pour a couple ounces of vegetable oil in and let it sit for several hours.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Campground Tees
Posted: 09/27/21 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Is it possible that there's a lip or sharp edge damaging the seals?
Any obvious damage to the old ones?
Cummins12V98
on the road
Posted: 09/27/21 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Specifically what toilet are you having issues with?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Janss
Sedona, AZ
Posted: 09/27/21 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Have you checked your flush mechanism (foot or hand)? While our seal is fine, it's our foot flush pedal that does not spring the blade completely shut. We have to get our foot under the pedal and lift up at the end of our flushing.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
dhull
Some Lake Some where
Posted: 09/27/21 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Try replacing the waste ball and waste ball drive. You need new drive to properly center the waste ball under the gasket. Otherwise you gotta lift it with your foot.
