RV.Net Open Roads Forum: Class A Motorhomes: Radial Tire Valve Core Failures
 > Radial Tire Valve Core Failures
Pangaea Ron
Anacortes, WA, USA
Posted: 09/27/21 11:54am Link  |  Quote  |  Print  |  Notify Moderator
My front radial tires are Toyo 245/75R 22.5.
When checking air pressure (105 pounds), I occasionally have the cores fail which allows air to escape dramatically, and I need to scramble to get the cap back on the valve stem on or replace the cores. This time I took it to Les Schwab Tires for them to check air pressures and to replace the valve cores. Both front tire valve cores had failed.
This seems to happen about every 6 months. Does anyone else have this issue. They said that it is common with high pressure tires?
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
CA Traveler
The Western States
Posted: 09/27/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
I'll stay tuned as this doesn't pass the smell test. A core failure every 6 months would mean that whatever the cause would very quickly have no sales and be a non product. Wonder how many OTR trucks with their high pressure tires have core failurs every 6 months?
Do you have beads, extenders or something else?
I've run 120 psi on my Toyo steer tires since 2011 with no failure. Do 90 psi duals qualify as high pressure? BTW IMHO many tire stores know little about larger tires including RV tires other than their lips are moving.
2014 Grand Cherokee Overland
Bob
MountainAir05
New Mexico
Posted: 09/29/21 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
if you are getting the replacement from the same place you need to change. You need to order some high pressure valve cores and install them. If you have car/light truck ones , yes then they will fail.
I too run over 100 lbs and not have a leak in many years. I do keep a pack of high pressure valve cores on hand just in case. I also put them in my other vehicles.
just look in my book and low pressure cores are good to 60 lbs and high pressure ones are good to 300. The ones I use on Vehicle /home air condition system are at 600. You could be getting them for the lower pressure of 60.
* This post was edited 09/29/21 05:10pm by MountainAir05 *
dodge guy
Bartlett IL
Posted: 09/29/21 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
I’m thinking you are over the valve cores max pressure. And why 105? Have you weighed the MH? I’m certain you don’t need to run over 80 psi. I run 75 per Michelin’s pressure/weight chart. My rear axle I run at 95 per the chart.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
ferndaleflyer
everywhere
Posted: 09/29/21 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
I run 105 also on the same size tire but I have never had a valve core failure.
RLS7201
Posted: 09/29/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect your tires have some sort of balancing stuff in them, causing the cores to not fully close.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
johnhicks
Wandering below the Gnat Line
Posted: 09/29/21 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
I've had the same cores since 2013, 110psi.
-jbh-
Yankee Clipper
Cairo, GA
Posted: 09/29/21 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
I run my Toyo tires at 90 psi. I'm weighing in at 21,200 pounds GVW.
You did not say whether you have extenders. I do, and would not be happy without them. That being said, I had a tire installer put a nylon stem on my prior Coachmen, and it got spit out like a watermelon seed.
Long way around to ask why so much pressure?
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS, Duke the overgrown Boxer mascot/lousy watch dog
Rosey the minidachshund resident Princess-in-Chief
Pangaea Ron
Anacortes, WA, USA
Posted: 09/29/21 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
105 is the recommended pressure. I bought a new compressor to achieve that.
Pangaea Ron
Anacortes, WA, USA
Posted: 09/29/21 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect that I have received low pressure cores? I'll verify that I now have the high pressure ones.
Thanks everyone for your input. I hate drama when I am only checking tire pressure. There are many more things to be concerned about!
