RV.Net Open Roads Forum: Class A Motorhomes: Radial Tire Valve Core Failures
 > Radial Tire Valve Core Failures
23hotrodr
Iowa
Posted: 09/30/21 04:51am Link  |  Quote  |  Print  |  Notify Moderator
I have the same issue at times. I will bet you have balancing beads in your tires and dust from them gets into the valve cores and holds them open. You need to give them a shot of new air before trying to check pressure to clear out the debris and let the cores to close. You should not rely on valve stem caps to hold pressure in your tires. There are valve stems with screens that are made to keep particles out of the valve cores that you can have installed to fix the problem. Or, you can just give them a shot of air before checking pressure to make them work properly. Good luck-- Mick
2007 Itasca Suncruiser 35L
2000 Jeep Wrangler
dodge guy
Bartlett IL
Posted: 09/30/21 04:56am Link  |  Quote  |  Print  |  Notify Moderator
Pangaea Ron wrote:
dodge guy wrote:
I’m thinking you are over the valve cores max pressure. And why 105? Have you weighed the MH? I’m certain you don’t need to run over 80 psi. I run 75 per Michelin’s pressure/weight chart. My rear axle I run at 95 per the chart.
105 is the recommended pressure. I bought a new compressor to achieve that.
I doubt your 08 is heavier than mine. Unless you had it weighed 105 is too high.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
dougrainer
Carrolton, Texas
Posted: 09/30/21 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Years ago, some of the big tire chains had millions of faulty Tire cores causing your exact problem. I wonder if your tire store somehow got hold of some of those old bad Cores. Doug
PS, the purchasing agent made a GREAT DEAL.
down home
south
Posted: 09/30/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
We had the left front wheel assy valve core come loose in Shawnee, Oklahoma. Chased down a Sap On Dealer to buy vale core tool to tighten it up.
I don't remember if the G670 tires were well balanced or not.
Cores that are inferior(cheap)may be the problem, as it was with the Chinese valve stems that caused the failure of all four tires on ourF150.
Other than that, out-of-balance sounds reasonable as a cause, without any real experience on the subject.
In my 73 years that one experience is the only one.
When we replaced the front or steer axle tires with Michelin "steer axle" tires with decoupling groves on the edge and center groove. It took 1/4 ounce of weight on one wheel and 0 as in none, on the other wheel.This on 285x22.5 tires and wheels. Outstanding! And the ride was smooth with more flexible sidewalls and in balance.
I have no idea how to identify a quality valve core but would question where you buy the next ones.
*Bad spec valve cores, the more likely or possibly metal valve stems, think is the problem. Everyone, that is the Tire sales places tend to buy all the same, cheap and the same brand.
If this is the case the problem will emerge over some time and the Dealers who sold and installed them will face big problems in reputation, and claims possibly including injury and death from wrecks.
This is one reason I check the tires with a laser pointed temp gun every stop, and the tire pressures checked and adjusted before we headed out. Checking tire pressure was a challenge for me, to get accurate readings so It was done by mgr where we stored it and at shops along the way if thought it needed.
fyrflie
Martinez, CA. USA
Posted: 09/30/21 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Although I have not had a valve core failure, I have had 4 of the six valve stems leak and while trying to tighten the nut to stop the leak, the threads strip out.
All of these valve stems are from Les Schwab. Cheap Chinese junk is what they sell.
I have had nothing but bad luck with their products and in my hometown store, horrible workmanship.
No more Les Schwab for me.
wallynm
Los Alamos NM
Posted: 09/30/21 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
We did a bead balance one time and had this problem. Replacing the valve stems will not solve anything IMHO. WE just lived with it. But relied on the TPMS to tell us when it was time put air in the tires.
Pangaea Ron wrote:
My front radial tires are Toyo 245/75R 22.5.
When checking air pressure (105 pounds), I occasionally have the cores fail which allows air to escape dramatically, and I need to scramble to get the cap back on the valve stem on or replace the cores. This time I took it to Les Schwab Tires for them to check air pressures and to replace the valve cores. Both front tire valve cores had failed.
This seems to happen about every 6 months. Does anyone else have this issue. They said that it is common with high pressure tires?
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
donkeydew
OR
Posted: 09/30/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
shoot me if you see me in a les schwab store. i would be completely out of my mind if i was even close to one
Mr. Pinky
Northern California Foothills
Posted: 10/05/21 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar experience with Les Schwab. If they used beads to balance the tires, there are special valve cores which must be used. I was stuck at a roadside stop because I couldn't get air in one of the tires and rescued by a trucker who was familiar with the problem. I went to a shop that specialized in truck tires and had all tbe valve cores changed. If the original cores are used, beads get inside the core and it won't retract so the air escapes.
"STUFF" HAPPENS, GET OVER IT
