RV.Net Open Roads Forum: Fifth-Wheels: Fresh water tank
 > Fresh water tank
mhardin
Texas!
Posted: 09/28/21 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Insects like to crawl up lines and build nests that cause blockages. Mud daubers are especially bad about it around here.
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
way2roll
Wilmington NC
M.R.E. wrote:
I wasn't blowing air up the low point drains for hot and cold water. It was the fresh water drain which also looks like a low point drain but is the fresh water drain. I pushed up the drain a coat hanger wire and felt a blockage and after going up and down for awhile it went up and drained the tank. I filled it and drained it and everything is fine. There must be some debris that blocked it.
That's awesome, glad you figured it out.
laknox
Arizona
Posted: 10/04/21 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Also, the people building these things don't much like to clean tanks out after installing them and also have a nasty habit of dropping fitting cutouts back into the tank instead of pulling them out. How many of us have read about this when a black/grey tank won't drain?
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
 > Fresh water tank
