d1h
Indiana
I have a tank monitor panel like this in my rv and one of the buttons broke. How hard would it be for me to replace it myself with a new one?
fj12ryder
Platte City, MO
Probably not that hard, just depends on where it's mounted and how easy it would be to get to.
Howard and Peggy
"Don't Panic"
2oldman
NM
valhalla360
No paticular place.
Assuming you are comfortable splicing wires...should be pretty simple. Just need to disconnect a wire from the old panel and connect it to the new panel then screw the new panel into the wall.
Though honestly, other than fresh water tank, they never work after the first couple uses. If you are trying to fix faulty readings, this won't do anything if they are connected to the same sensors.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Lynnmor
Red Lion
Since it is only the button that is the problem, simply pop out the panel with a tiny flat screwdriver and unplug the wiring. Then plug the wiring into the new panel and pop it back in.
bgum
South Louisiana
One wire at a time. Or one toe over the line.
Likely easy to replace but...
Good time to upgrade
https://www.garnetinstruments.com/rv-shop/
fj12ryder
Platte City, MO
valhalla360 wrote: Assuming you are comfortable splicing wires...should be pretty simple. Just need to disconnect a wire from the old panel and connect it to the new panel then screw the new panel into the wall.
Though honestly, other than fresh water tank, they never work after the first couple uses. If you are trying to fix faulty readings, this won't do anything if they are connected to the same sensors. Exactly so.
deltabravo
Spokane, WA
wa8yxm wrote: Likely easy to replace but...
YEP. See Level tank monitor upgrade is my favorite upgrade ever.
Dusty R
Charlotte Michigan 48813
That's a vary nice system, much better than measuring in thirsts. one third, can be almost empty, or quite a bit in the tank. Also it is not very hard to install.
