RV.Net Open Roads Forum: Class C Motorhomes: Heavy Class C Tire thoughts
 > Heavy Class C Tire thoughts
Page of 5
Holiday27
Gresham, OR.
Posted: 09/30/21 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
bobndot wrote:
All of the issues I've had with the toyos have been separations (4 in all over 8+- years). 1 was after only 500mi!. So honestly, I'm over toyos. Time to try something new for me.
I understand how you feel regarding ‘moving on’. The Cross Climate seem to be a vg choice with the @3100# rating.
Were those previous 4 separated tires from the same purchase ? Over 8 years ?
If so, that could have a bad lot. Mfg defect or age ?
Tire separation is normally mfg related but can be heat, PSI or age related which can and has occurred most all tire brands including Michelin.
No, I had upgraded the tires after purchase a couple years later. The tire that separated in 500mi replaced another tire that separated, so not a "lot" thing. My coach is very heavy so not bad mouthing Toyo. I suspect I'll have similar issues down the road but with added weight rating maybe I'll get lucky!
2002 27PBS Holiday Rambler (Aluminum sided/roof) Love it!
Previous RV's
'94 Jamboree 22ft. (This beast had a 460 with tons of power)
'95 VW Eurovan camper (5 cyl. dog) Pulled a 3 rail fine though.
Tent">
Borrowed folks '84 VW Westfalia (water cooled)
RambleOnNW
Pacific Northwest
Posted: 09/30/21 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
whemme wrote:
Sorry to say but all E rated tires of a certain size by any brand have the exact same max load carrying capacity when inflated to 80 psi.
Actually not. You can see from the Michelin load tables that the dual application of the C-Metric 225/75-R16C has 1000 lbs. more per pair or 2000 lbs. more per 4 rear tires at 80 psi. 5950 vs. 4940 lbs. per pair.
https://www.rvsafety.com/images/pdf/michelinloadandinflationrvtruck.pdf
2006 Jayco 28', E450 6.8L V10, Bilstein HDs,
Roadmaster Anti-Sway Bars, Blue Ox TigerTrak
Holiday27
Gresham, OR.
Posted: 09/30/21 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
RambleOnNW wrote:
Holiday27 wrote:
I think I'm sold on these. The weight capacity seems pretty great and price is ok. Capacity appears higher that regular E rated tire maybe due to commercial rating.
Michelin - Agilis CrossClimate 225/75R16C 121/120R LRE
https://tires.costco.com/product?ItemNo=1331851
I looked at those too and it will be interesting to hear how they turn out. Those tires check a lot of boxes, sidewall protection, true all-season with Mountain snowflake winter rating, weight rating. Note that the C-Metric version has a directional tread whereas the non-C metric version does not. So each dual set of wheels will have to have a left and right tire? What to use for a spare, a non- C-metric Agilis?
For me it was go with what you know. Bridgestone all-steel cased tires were dependable for 8 years and the tire weight of 51 pounds.
Thanks for pointing out the directional thing. I didn't notice that. Honestly it doesn't matter to me though because I don't rotate my RV tires. For my spare I'll use my newest Toyo tire which I think is about a year old so non issue.
I'll keep you posted on the crossclimates!
Holiday27
Gresham, OR.
Posted: 09/30/21 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for pointing that out. That's what I was thinking as well.
whemme
Spencer, IA
Posted: 10/01/21 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
But the Michelin 225/75-R16C is not an E rated tire. You are trying to compare apples to oranges.
2002 Born Free 26' RSB Motorcoach
2005 Chevrolet Malibu LS Toad
Holiday27
Gresham, OR.
Posted: 10/01/21 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
I think it is. See load range in link.
https://www.tireamerica.com/tires/sku/mi........25-75r16c-121-120r-e/000000000001114984
RambleOnNW
Pacific Northwest
Posted: 10/02/21 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
So what Load Range do you think it is? It says right in the table it is an LRE.
CapriRacer
Somewhere in the US
Posted: 10/03/21 03:34am Link  |  Quote  |  Print  |  Notify Moderator
Perhaps I can explain this.
First, whemme is mostly right, but he could have worded it better.
But RambleOnNW is sort of right, too - and he also could have worded it better.
What is going on here is the difference between tire standardizing organizations. Whemme is referring to LT tires (US based standard) and what RambleonNW is referring to are C type tires (European based standard). They use the same number for the tire dimensions, but they use different formulae to figure out the load carrying capacity.
Technically, LT tries (US standard) come in Load Ranges, while C type tires (Euro standard) come in Load Indices (not load ranges). But tire retailers aren't quite this savvy, so they fall back on what is familiar - Load Ranges - and label these C type tires with Load Ranges (incorrectly!)
I hope that explains things.
CapriRacer
Visit my web site: www.BarrysTireTech.com
RambleOnNW
Pacific Northwest
Posted: 10/04/21 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
... But tire retailers aren't quite this savvy, so they fall back on what is familiar - Load Ranges - and label these C type tires with Load Ranges (incorrectly!)
It is not just tire retailers that call the C-Metric tire a Load Range E. Michelin themselves market the Michelin Agilis CrossClimate 225/75-R16C LRE as a Load Range E:
https://www.michelinb2b.com/wps/b2bconte........GILIS_CROSSCLIMATE_B2B_product_sheet.pdf
* This post was edited 10/04/21 04:36pm by RambleOnNW *
bobndot
Posted: 10/04/21 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
One of our members switched to the following tire.
The LT235/85/16E is 3040#. It fits the OEM wheels that the 225 75 16 rolls on and at a little over one inch in diameter larger will offer you about 1/2” more ground clearance while fitting the wheel wells. Seems to me to be a good option bc it offers two advantages over the stock LT225 75 16E.
Page of 5
