RV.Net Open Roads Forum: Tech Issues: Refer died
 > Refer died
pismopete
central cal
Posted: 09/28/21 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
My Dometic RM2852 needs to be replaced. Does anyone know what I have to order to replace it that will fit in the same opening? Thanks for your help.
Boon Docker
Posted: 09/28/21 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
One of these replacement cooling units. Quite easy to replace.
Posted: 09/29/21 05:03am Link  |  Quote  |  Print  |  Notify Moderator
I agree with Boon Docker don't replace the whole thing just the cooling unit.
Other wise go to the Dometic web page and read the size specs.. Most of them are one of 3 sizes. But I'd replace the cooling unit.. in fact.. I did.
pismopete
central cal
Posted: 09/29/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
SJ-Chris
San Jose, Ca
Posted: 09/29/21 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same refrigerator on one of my 2015 RVs stop cooling. Here is a great post you definitely should read in it's entirety. It should save you some $$$ and illustrate that it is fairly easy to replace your cooling unit if it is bad.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/30167880/srt/pa/pging/1/page/1.cfm
Happy Camping!
Chris
San Jose, CA
Own two 2015 Thor Majestic 28a Class C RVs
huntram
Fulltiming in the RV
Posted: 09/30/21 09:30am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't say it's "quite easy" to replace a cooling unit. Most RV Repair shops won't even do it anymore because it's so much work. Having said that my buddy and I (mainly him with my help) have replaced two so far. RV Enthusiast Magazine May 2021 has a full breakdown on how to do this.
Our traveling blog:Brian and Patty's Awesome Adventure
2014 Ram 3500, Western Brown, Laramie, CrewCab Dually, Aisin Trans, CTD, 2011 Carriage Cameo 32FWS 5th wheel.
dougrainer
Carrolton, Texas
Posted: 09/30/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
I have been replacing Cooling units for 42 years. For me, It is as easy as pie. I can replace a 4 door 1200 Norcold Cooling unit is less than 2.5 hours. A standard 6 or 8 CF 2 door in about 1.5 hours. Where do you get your knowledge that "Most RV repair shops won't do it anymore"? The PROFIT is extremely worth while for some shops. The use rebuilt and charge almost as much as new for the part and charge from 4.0 to 6.0 hours labor. If the shop states it is too much work, I would NEVER have them work on anything for my RV. Doug
Boon Docker
Posted: 09/30/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Not sure why you think it is a lot of work, took me less than a hour to replace mine.
 > Refer died
