EydieG
Bonaire, GA
We have a 38 ft Dutch Star diesel pusher. We have been towing a Jeep Grand Cherokee for about 7 years but now thinking about a truck. Not a big truck, but one that can pull our 19ft boat (not at the same time it is being towed, of course). What kinds of trucks can be towed 4 down without much effort? our Jeep Grand Cherokee has been so easy to hook up to our blue ox, we are kind of spoiled.
Thanks for any suggestions!
Brand new owners of a 1999 Newmar Dutchstar DP
dodge guy
Bartlett IL
Any 4WD 1/2 ton with a N position on the T-case. A Chevy Colorado can tow that size boat as well as a Jeep Gladiator.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
deltabravo
Spokane, WA
2015+ Chevy Colorado GMC Canyon can be flat towed.
I have a 2017 with the 2.8L Duramax. Powerful little truck.
I towed this with it across WA State when I bought the truck and got 19-20 mpg.
way2roll
Wilmington NC
Dinghy towing guides
bikendan
Goodyear, Arizona
Should be moved to the Dinghy Towing section
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Owens River area
Check with the manufacturer on-line before you buy…and carefully.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
BruceMc
Oregon - Willamette Valley
We tow a 2012 GMC Canyon 4WD:
![[image]](https://a4.pbase.com/g12/88/791988/2/171964147.MO9sjU3y.jpg)
Dead simple setup when readying to tow.
Hook it to the tow bar, then flip a switch to enable supplemental brakes, as I installed the Demco Stay-N-Play braking.
To put the transfer case in neutral, turn on the ignition, step on the brakes, put the gear selector in neutral, then hold 2H and 4L together for 10 seconds. After the N indicator lights up, put it in park and pull the key.
Done.
The 2nd Generation Colorado/Canyons are a bit more involved, but they are towable, as is the new Rangers.
As Way2Roll mentioned, consult the towing guides, then download the user manuals for those vehicles you are interested in. If the towing guide says a vehicle is towable, then verify as the manufacture's user manuals are the definitive guide.
'16 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Previously:
'00 Four Winds 26Q Class C (Ford E350 V10)
'96 Kit Sportsmaster 212f Fifth Wheel/'93 GMC Sierra K2500
'91 SunLite poptop truck camper
and the first: a Wildernest flip-top canopy.
^Hey are you brucemac with the Prostar 205V?
2017 Heartland Torque T29
mowermech
Billings, MT
dodge guy wrote: Any 4WD 1/2 ton with a N position on the T-case. A Chevy Colorado can tow that size boat as well as a Jeep Gladiator.
Keep in mind that not all Hi-N-Lo transfer cases can be towed four down! There are a few that will not properly lube the bearings and seals when being towed in Neutral. I once had a Jeep CJ7 that could not be towed without modifying the transfer case. I sold it.
ALWAYS read and follow the manufacturer's recreational towing instructions!
CM1, USN (RET)
2010 North Trail 28BHS TT
Daily Driver: '14 Subaru Outback
Toy: '05 Wrangler Unlimited
Towing: 1999 Dodge QC LWB, Cummins, Auto, 4X4
Other toys: 2 Kawasaki Brute Force 750 ATVs.
BruceMc
Grit dog wrote: ^Hey are you brucemac with the Prostar 205V?
No.... Prostar 205V?
I'm "BruceMc", not "brucemac".
