RV.Net Open Roads Forum: Tow Vehicles: Tires
Search only in Tow Vehicles
 > Tires
Charlie D.
E. Texas-Orange
Posted: 09/29/21 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Goodyear Wrangler Trail Runner
LT275/65R20 has a very small leak. Aired to 75 PSI on September 15. As of today it is at 64 PSI.
Took it to a dealer and they found the leak. Can still see the nail.
Looks, for those old enough, like a paneling nail.
Told me it could not be repaired and quickly offered to install a new one.
Tire has less than 12,000 miles.
See photo. It is inside the white circle.
What is your opinion?
It is my gut feeling that if I should replace it, I should replace both.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
BenK
SF BayArea
Posted: 09/29/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
No image shows up…think your formatting isn’t correct
Here is the RMA image showing where the repairable area is and where it NOT recommended to repair.
Make no matter how many miles is on the tire. Risk is a blowout from flexing at the stress raiser around the repaired area
Plus the tires speed rating is no longer warranted by the OEM once a tire has been repaired. Especially high speed rated tires.
-Ben Picture of my rig
mkirsch
Rochester, NY
Posted: 09/30/21 07:06am Link  |  Quote  |  Print  |  Notify Moderator
If the tire dealer didn't insist that you had to install two, I wouldn't worry about installing two. Wouldn't even consider it.
corvettekent
Marysville, WA
Posted: 09/30/21 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Just replace the one tire.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Posted: 09/30/21 08:32am Link  |  Quote  |  Print  |  Notify Moderator
First make sure it’s not repairable. Many Tire shops are are more conservative than necessary for multiple reasons (liability and profit).
Next, depends how many burnouts you’ve done with the matching one? to determine if you need 2. But I bet there’s a very slim chance that replacing both tires is preferable based on the mileage on the tires.
2017 Heartland Torque T29
Cummins12V98
on the road
Posted: 09/30/21 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Small puncture patch it and carry on!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 09/30/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Had a similar experience with our Malibu, picked up a screw just outside the repairable area. The Tech at the Tire place I deal with admitted if it was his, he'd repair it and carry on, BUT because we were a Customer he couldn't repair it for fear of losing his license.
Thank you our Government at work to protect us.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Lynnmor
Red Lion
Posted: 09/30/21 09:18am Link  |  Quote  |  Print  |  Notify Moderator
They won't repair one that has damage at the tread edge.
To open the image, I right clicked on his image link and clicked on open in a new tab.
ford truck guy
Pennsylvania
Posted: 09/30/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
NOT always true.... IF the puncture is within 1" of the sidewall on the tread, they are NOT going to repair...
If the puncture is more than an inch away from the sidewall, plug-patch ( umbrella patch) is the best of both worlds.
With that said.,,, if not repairable, buy 1 not 2
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Charlie D.
E. Texas-Orange
Posted: 09/30/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys. As Lynnmore stated "right click on the image, save image as" and the photo will show up on another link
 > Tires
