RV.Net Open Roads Forum: Class A Motorhomes: 2006 Sunova 12V ground problem.
 > 2006 Sunova 12V ground problem.
enblethen
Moses Lake, WA
Posted: 10/07/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check for 12 volt DC output?
Check for 120 volt input to converter?
Did you check the reverse polarity fuses on the converter, if equipped.
Make and model of converter?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Rolin
Oregon
Posted: 10/08/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Hi Enblethen,
- Checked the 12v output...shorted by accident and tripped a breaker. I was in a panic for a few minutes until I found the breaker that was tripped. Working on a friends MH, my goal is do no harm.
- Verified 120v input to the converter
- Converter has two 30A fuses and verified they are both good with an ohm meter.
The Converter is a Magnetek 7400 series. At least it matches the description given on Best Converters website where they list obsolete converters. The converter has one green wire that is grounded to the frame, and two black wires. One goes to the breaker panel, the other I assume toward the front of the MH where I found the tripped breaker.
I would recommend they get a new converter but want to be sure we know what the problem is before moving on to improvements.
Thanks for the inputs,
Rolin
enblethen
Moses Lake, WA
Posted: 10/08/21 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Is there 12 volts dc on both sides of each of the reverse polarity fuses?
There should be in most 12 volts panels a fuse going to the converter and/or one for Bat.
Tripped circuit breaker was a 12 volt DC one? That could indicate the converter or batteries are reversed polarity.
* This post was edited 10/08/21 08:28pm by enblethen *
Rolin
Oregon
Posted: 10/14/21 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
Problems resolved:
Engine not starting was because of poor connection in battery compartment. Working great now
Dead House Batteries was due to a poor connection from the converter to ground on the frame. Took awhile to locate where the wire attached to the frame. The nut securing the ground wire was loose. Cleaned the area and tightened the nut. Now the converter is charging the new house batteries like it should.
Thanks everyone for your help.
enblethen
Moses Lake, WA
Posted: 10/15/21 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update!
Safe travels.
