RV.Net Open Roads Forum: General RVing Issues: Home - Waste Dump
 > Home - Waste Dump
Lakejumper
Northern California
Posted: 09/30/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Iā€™m having my sewer clean out moved out from underneath our home. I want to be able to dump the RV in it. What size line should we use, 3ā€ or 4ā€?
Lakejumper
2016 Winnebago Vista LX 30T
2012 Chevy Equinox
Dick_B
Palos Heights, IL USA
Posted: 09/30/21 11:58am Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking the plumber would decide that but I think ours is at least four inches; probably more like 6.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
rk911
DuPage County
Posted: 09/30/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
sewer clean-out access are almost always at least 6"...ours at home is. i have our line cleaned out annually to prevent nasty backups. the guys were here yesterday and used a 6" cutter.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
RAllison
Millersburg,ohio
Posted: 09/30/21 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 4" pvc line for my cleanout, works fine.
ford truck guy
Pennsylvania
Posted: 09/30/21 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
We don't have one at home, but at the shop ours is 4"
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
corvettekent
Marysville, WA
Posted: 09/30/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is 4" but yours should be what ever size pipe that you connecting to.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Lynnmor
Red Lion
Posted: 09/30/21 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a septic tank, there should be a line in, a line out and a cleanout in the lid. You don't want to dump in that cleanout, instead you should have a tee in the line that goes in. I suspect that your "cleanout" is a Y on the pipe from the house to the septic tank and that would be fine for dumping as long as you maintain a capped Y for future clogging issues. For your dump line, 3" or 4" is fine, the most common size is 4".
In my area they are pushing for installation of a manhole in the tank lid so it can be properly inspected. Yes, pumping and inspection is now required.
LittleBill
Scranton, PA USA
Posted: 09/30/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
buy a macerator and just send it down the toilet. or a 2 inch line will work for the hose.
Flojet Macerator
Boon Docker
Posted: 09/30/21 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a 3" line for my macerator and it works fine.
Beaker
Brevard, NC
Posted: 09/30/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
I "sent it down the toilet" and smelled up the house. Never again.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
 > Home - Waste Dump
