RV.Net Open Roads Forum: Travel Trailers: ATWOOD WATER HEATER WON'T SHUT OFF
 > ATWOOD WATER HEATER WON'T SHUT OFF
LVJJJ
NW WASHINGTON
Posted: 10/01/21 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Got an '05 Trail Cruiser, 6 gallon HWT took a long time to get hot so replaced the propane valve. Now I have a nice hot powerful flame. Now it won't seem to shut off the flame even after 1/2 hour and the water is really really hot. So replaced the two thermostats. Still won't shut the flame off. Now what?
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
enblethen
Moses Lake, WA
Posted: 10/01/21 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Start by verifing wiring. Could be ECO and thermostat wires are backward.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MT BOB
Montana
Posted: 10/01/21 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Probably would help if you posted the model # of the water heater.
larry cad
ohio
Posted: 10/01/21 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Verify the two thermostats are in physical contact with the water tank so they can measure the actual temperature.
Our Travel Blog
Skibane
San Antonio, TX
Posted: 10/01/21 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
While the burner is lit, try pulling one of the wires off the propane valve.
If the burner continues to run, the valve is sticking - and defective.
hohenwald48
Nashville, TN
Posted: 10/05/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Check the water temp with a thermometer. "Water got really hot" is not very specific. RV water heaters get significantly hotter than the water heater in your home.
A 6 gallon tank will take about 30 minutes to heat up a tank full. A little longer would not be surprising.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
ISBRAM
Denver, Colorado
Posted: 10/08/21 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
My last campers water heater didn't have a mixing valve and it shut off at around 120F. My Airstream's Attwood does have a mixing valve on the water heater outlet I think it runs up to around 180F before it shuts off. I'm told the idea is a 6 gallon water heater with a mixing valve that heats the water hotter will give you the equivalent supply of a much larger water heater.
1999 Dodge Ram 2500 QC LB Cummins
2013 Airstream International 25FB
If you see me camped someplace stop and say hi, I've always got an extra ice cold beer.
