RV.Net Open Roads Forum: Class A Motorhomes: TorqShift Transmission
 > TorqShift Transmission
Big Jimmy
Livermore
Posted: 10/01/21 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2011 Tiffin allegro 32ca with a V-10 and TorqShift Transmission - Problem - in Tow/Haul going downhill when you hit brakes it shift down and if you hit the brakes a second time it shifts down again and RPM's go way "UP" big time, scary!! Is this normal? thanks
Jack_Diane_Freedom
Burlington Ontario Canada
Posted: 10/01/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Doing what it is supposed to do. Absolutely normal.
Krusty
Calgary, Alberta,Canada
Posted: 10/01/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Yup. Doing what it is designed to do to help slow you down without overheating the brakes. Don't worry. Your engine was built to rev and it won't hurt it a bit.
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
valhalla360
No paticular place.
Posted: 10/01/21 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
That is what it is supposed to do but...
What are the RPM you are seeing?
- 3000-4000RPM, perfect.
- If it gets above 5000RPM, give it some brakes to keep the RPM below 5000.
When you use the brakes going down hill, try not to build up too much speed. Once you are going fast, it's much harder to get it slowed back down. When it gets too high, apply the brakes firmly so it slows down 15-20mph and the RPM gets down to a more reasonable level. Then let it creep back up.
Do not just ride the brakes lightly. This will heat up the brakes until they are literally red hot. At that point, they will lose a lot of their stopping ability.
By using short hard braking, they have time to cool off between uses.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Big Jimmy
Livermore
Posted: 10/01/21 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the information, can you engage or disengage the tow/haul while you are moving?
DrewE
Vermont
Posted: 10/01/21 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, you can switch tow/haul on and off at any time, moving or not, just as you can shift in and out of overdrive, etc. at any time.
Frankly, there's little reason to disengage it, particularly when it's providing good engine braking. The engine/transmission computer won't do things that damage the engine or transmission; while the higher RPMs may sound a bit scary, they are not a problem and within the design limits of the system. (The V10 is a fairly high revving truck engine, in general, and having at least two more cylinders than most other truck engines makes it sound somewhat like it's spinning that much faster than it actually is.)
Posted: 10/01/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
If it works the way I think it does it will NOT over rev the engine
It will kick it up right close to red line. But not over .
Also if you are on a long grade and the speed climbs, and thus the RPM's. it will upshift...
Key phrase "If it works the way I THINK it does"
shum02
Burlington ON CDA
Posted: 10/02/21 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Yup, it will not over rev the engine. Just like if you try to manually pull down a gear by manually downshifting it will not do it until the computer determines it is safe to do so. Love the T/H system.
This was Ford's first attempt at stuff like this with a fully electronic transmission and it worked out pretty good. I have over 300k miles on mine with regular service and have only had to replace a sensor.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
dodge guy
Bartlett IL
Posted: 10/02/21 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Anytime you start the engine you should automatically turn tow/haul on. The MH is always loaded to near its max GVWR. Tow Haul helps with acceleration as it raises the shift points. And yes it’s supposed to down shift when braking as everyone said. This again helps because it’s loaded to its GVWR.
So yes it’s operating as designed.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
MFL
Midwest
Posted: 10/02/21 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Yes, tow/haul is working as designed. The TorqShift has several options. I am towing a FW, and sometimes double towing, on long steep grades, with sharp curves. I prefer to shut off T/H, and use manual mode for lengthy downhills. Otherwise, every time I tap the brakes, due to lots of curves, it will down shift more than I want. I can also lock out upper gears, restricting the use of 6-5 or even 4th if needed.
It is a great transmission!
Jerry
