RV.Net Open Roads Forum: Do I Want to Break Down Solids?
 > Do I Want to Break Down Solids?
wanderingbob
monticeeo, fla
Posted: 10/02/21 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Use your black tank flush like a loaded gun , you only get one chance to screw every thing up . Do not turn it on a go to a movie or rodeo , stand right there and !
Cummins12V98
on the road
Posted: 10/02/21 10:33am Link  |  Quote  |  Print  |  Notify Moderator
I have my cell phone on me with a loud "BARK" for the alarm. EASY to get distracted and then the dreaded POOP Volcano comes shooting out the vent on your roof!!!
Only time I get any odors is if I have an exhaust fan running as it will suck odors up thru the toilet drain hole when flushing. I add about one minute of water using the flush with tank drain closed.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Near Bishop, California
Posted: 10/02/21 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Plenty of water and a short drive is all you need for a good dump.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Super_Dave
Harrisville, UT
Posted: 10/02/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
My black tank sensor has never worked, reads 2/3's full even when empty.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
pianotuna
Regina, SK, Canada
Posted: 10/02/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
If they can't make a reliable sensor for a Nuclear plant, how do you expect the "two bit" RV makers to create one that is reliable?
Regards, Don
Timmo!
Far away from this WOKE website!!!!!!!!!!!!!!!!!!!
Posted: 10/02/21 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Dumping a bags worth of ice also is a great way to "clean" the black tank as well and breakdown (macerate) those silly brown pickles.
noteven
Turtle Island
Posted: 10/02/21 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Video 1 of 4 of a famous series:
See inside RV black tank
nagel
Missouri
Posted: 10/03/21 04:07am Link  |  Quote  |  Print  |  Notify Moderator
All good comments. Wasn't my intention on starting the sensor debate again, but good thoughts. I was more reacting to the thought of not using something to break down solids in you tank. Like some said solids will naturally breakdown, but if I don't put something in the tank to help will it create a "dam" inside the tank. Probably not if enough water is used. I guess everything I've ever read or watched has always inferred that you want your black tank to be "mush" and this guy who is a "professional" is indicating the opposite and supports his position by saying the "pancake batter" affects sensors in a negative way.
The Video: https://www.youtube.com/watch?v=wr4TGBPyPe0
What I've heard: https://www.youtube.com/watch?v=GyWMyZ02_7M&t=225s
Steven R. Nagel
way2roll
Wilmington NC
Posted: 10/03/21 06:47am Link  |  Quote  |  Print  |  Notify Moderator
If you ask me, it's way overthinking it. It's a holding tank, not a septic tank. Stuff only stays in my tanks for 4-5 days at the most. Not nearly enough time for any real breakdown to occur without caustic chemicals, and to what end? Lots of water, no problems.
CavemanCharlie
Storden,MN
Posted: 10/04/21 10:20am Link  |  Quote  |  Print  |  Notify Moderator
I would think that if your "Solids" are so solid that they don't break down in water easily anyway that you need to eat more fiber.
