RV.Net Open Roads Forum: General RVing Issues: Mildew
rickhise
home
Posted: 10/02/21 05:57am Link  |  Quote  |  Print  |  Notify Moderator
Right now I keep a box fan running.
What humidifier do u recommend? prefer a unit
I can put a hose in the straight drop.
Also running the box fan 24 / 7 presently
Thinking a timer might help an turn off during the
Hottest period of the day
28 ft pull behind under carport
Thoughts thanks
rickhise
home
Posted: 10/02/21 06:00am Link  |  Quote  |  Print  |  Notify Moderator
Also any sprays to use b4 mildew occurs makes wiping/cleaning off
easier
joelc
Cedar Point, NC
Posted: 10/02/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
For mildew you need a dehumidifier or/and run A/C. Use a good spray especially if you have the black stuff. Clean with vinegar and spray. I used Microban. When we leave our camper we run the dehumidifier at 40. NOT A HUMIDIFIEER.
prichardson
Lafayette, La
Posted: 10/02/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Ventilation is the key. Leave at least one roof vent open and a window at the the opposite end partially open. With good ventilation you shouldn't need anything else. In mold prone areas (like showers) use Mold Armor.
Bobbo
Wherever I park
Posted: 10/02/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
This ^^^^^^^^^^^^^^.
I put vent covers on my rooftop vents so I can leave them open regardless of weather. (Also, I disabled the automatic closing in wet weather.) I leave both vent covers fully open when in storage. With the vent covers keeping rain out and the vents letting air circulate, I have never had a problem with mold or mildew.
Bobbo and Lin
2oldman
NM
Posted: 10/02/21 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Mildew inside? You don't want to be living with that.
Timmo!
Far away from this WOKE website!!!!!!!!!!!!!!!!!!!
Posted: 10/02/21 11:50am Link  |  Quote  |  Print  |  Notify Moderator
If the humidity is really high, adding ventilation may do very little to control mildew, lowering the humidity is the answer.
We have an upstairs bathroom with a window that does not open and we live in the Willamette Valley where mildew prospers handsomely (unabated, it appears in the shower overnight).
This little 14" tall baby (Ivation GDM30) is what I have and suggest. It is designed to work within 2200 cubic feet (almost equivalent to a 39' RV) and pulls about 20 ounces of water per day (86 degrees and 80% humidity) and tank capacity is 50 ounces. Want a bigger tank? Then purchase a bigger unit.
https://www.ivationproducts.com/products........m30-midium-thermo-electric-dehumidifier#
About every 10-20 days we empty the reservoir and have it on a timer; off at nighttime and on in the morning. WE HAVE ZERO MILDEW ISSUES.
And, if you want to run it at 12VDC, then eliminate the 120 VAC power adapter.
Lumpty
Greater Gotham City
Posted: 10/04/21 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
I have MaxAir covers over all my roof vents which are open when the RV is not in use. Anytime expect the heat of summer, I will use multiple DampRid tubs to suck the moisture out of the inside air. During winter, I'll change them out every couple of months. I also leave cabinet doors, the fridge and microwave open.
Never had any mold/mildew issues, even living in the northeast with a lot of humidity and temperature swings.
Rob
Too Many Toys.
- '11 E450 Sunseeker 2300
- '16 F150 Supercrew 5.0/FX4
- '09 C6 Z51
- '15 VW Golf Sportwagen daily driver
- '86 Civic and '87 CRX race cars
2012Coleman
Posted: 10/05/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I live in Florida. When I go inside my camper after it's been shut up a while in the summer, it's hot, but it isn't humid. I have never got the advice to leave a vent open. I wouldn't do that.
Since it's under a carport, it is in the shade. Mold/mildew grows in dark humid conditions. So run the dehumidifier and drain into the sink. Open all interior doors and maybe use damprid in the bathroom.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
