RV.Net Open Roads Forum: Travel Trailers: 2021 No Bo 19.5 bent axle
 > 2021 No Bo 19.5 bent axle
SavannahChicago67
Pooler ,Georgia
Posted: 10/02/21 07:21am Link  |  Quote  |  Print  |  Notify Moderator
I just returned from a round trip from Savannah to Georgianna, Al., and was having some work done on my trailer, and was informed by the tech that my axle was bent on the right side, and was causing damage to my tire. I did not hit anything on the road, and the only incident of any kind was roling over a 4" curb at my campsite, going about 5mph. Neither my wife or I noticed anything on the drive home (260 miles), and the trailer was not overloaded, fresh, black and grey tanks were empty.
I am curious if anyone else has had issues with their single axle travel trailers?
Skibane
San Antonio, TX
Posted: 10/02/21 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Not with axles, but bent wheels are somewhat common. Apparently, the way they are packed for shipment to trailer manufacturers makes them easily damaged in transit.
Lynnmor
Red Lion
Posted: 10/02/21 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Most trailer axles are marginal at best, banging over a 4" curb probably bent the axle. Consider replacing it with a stronger part if possible.
carringb
Corvallis, OR
Posted: 10/02/21 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Yup. Small tires over a curb with a light-wieght axle can easily bend it.
It would be good to figure out what you have now. If you only have a 2200# axle, a 3500# should be an easy upgrade.
2014 ORV really big trailer
2015 Ford Focus ST
Posted: 10/02/21 11:12am Link  |  Quote  |  Print  |  Notify Moderator
That stinks. But if one wheel is dog tracking then it’s likely bent.
Good news is not too expensive and maybe you can upgrade the axle if it’s maxed out.
2017 Heartland Torque T29
SavannahChicago67
Pooler ,Georgia
Posted: 10/02/21 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
The No Bo 19.5 has full sized tires, and a curb weight of around 3500 lb + another 1300 pounds of carrying capacity, and it was NOT heavily loaded- no fresh, grey, or black water- just food and clothes for a week.
SavannahChicago67
Pooler ,Georgia
Posted: 10/02/21 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
could a bent wheel affect the axle?
Gdetrailer
PA
Posted: 10/02/21 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Anything is a possibility or guess at this time.
Looking at your model given it has a Torsion axle (no external springs) which uses a molded under pressure chuck of rubber to act as a spring. With torsion axles the axle stub is on a arm and that arm twists the rubber. So, it is possible jumping a curb, hitting a pothole or even a badly bent wheel could do some sort of damage..
Or the rubber inside the axle tube just failed for no reason..
phillyg
SWFL
Posted: 10/03/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Doesn't matter if the axle was barely adequate from the factory. Regardless, if it's damaged and affecting a tire, it needs to be replaced and/or upgraded.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
JIMNLIN
Oklahoma
Posted: 10/03/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
I big rig trailer repair shop can bend the axle back to specs and have you on the road in short order.
Rolling over a curb at 5mph ?
That quite a impact especially if the trailer was going around a corner and with the tires side scrubbing "into" the curb.
One of the two big rig trailer repair shops I've used said they see lots of lead axle/curb side bent wheels and axles....cut tires or just outside rubber cuts on rv trailers.
A bent wheel won't bend a std leaf spring suspension axle. Jack the wheel up enough to roll it by hand. If it wobbles its bent and needs replaced....and have that tire checked internally.
