RV.Net Open Roads Forum: Tech Issues: PUZZLER: Slides & jacks are dead
 > PUZZLER: Slides & jacks are dead
dedmiston
The West
Posted: 10/02/21 10:55am Link  |  Quote  |  Print  |  Notify Moderator
I'm having trouble with two systems in our fifth-wheel.
We have two slides in the living area (connected) and a bedroom slide. We also have Lippert leveling jacks. The functioning bedroom slide is a cable slide, and the living area slides are rack & pinion. I don't know whether they're hydraulic or not.
First some background and then the symptoms...
_______________________
Background:
We dry camped last weekend and I thought our batteries were going bad. We have 700w of solar panels that always do a great job, but we camped at the beach where it was drizzly and overcast most of the weekend and the solar wasn't much use.
When we left at the end of that weekend, the jacks were hard to retract. The motor bogged down and the battery voltage dropped. I didn't pay attention to the actual voltage on the panel beyond seeing that it had dropped a lot. I ran the gen and that helped, but not as much as I expected. I don't know if the gen was actually assisting, or if it was just the stopping and waiting that made the difference.
When we got home and put the fiver away in storage, I ran the gen while I unhooked and deployed the jacks & leveled. It was still labored.
I assumed that my batteries suddenly lost their will to live, so I replaced them with four more similar GC2 6V on Thursday. The batteries were five years old and kind of swollen, so I figured this would be the fix.
Actual Problem:
After installing the new batteries, I hooked up the shore power to our 50A connection at home overnight and left it connected.
Mid-day I opened the slides to pack a few things before this weekend's trip (now cancelled). The slides were really hard to deploy and retract. The bedroom slide worked fine though.
Later in the afternoon when it was time to leave, I tried to run the slides out again, but the switch was dead.
It makes a "thunk" sound in the front compartment where the batteries and gen live. That's it. Just "thunk", but no movement.
I called my mobile tech and he told me to look for a reset switch, but I never found one. (He came out later and couldn't find one either).
Before he came out, I tried the jacks too just for kicks, and the jacks were dead too. Just a "thunk" in the same spot.
I checked all the breakers and fuses and everything is good. Ditto for the battery voltage, and I'm still plugged into shore power. I also disconnected the shore power just for kicks to see if that made any difference.
It feels like there's some kind of switch that is tripping when the motor thinks it's hot. Before bed, I tried to retract the jacks again because I can't keep the fiver in front of my house another night. The jacks retracted in the cooler evening, but the motor quit just as they were finishing retracting.
My tech thinks the problem is with the hydraulic pump, and he thinks it's shared between the jacks and the slides. I don't necessarily agree. Yes, the "thunk" is common and shared, but I don't believe that the slides share the same hydraulic system (if they're hydraulic). I've watched the fluid levels carefully when I deploy/retract the jacks, and the level stays the same whether the slides are in or out.
As it stands now, I have no jacks and no slides. I'm leaving for storage in a minute and I'll probably have to use my drill to run the jacks down so I can unhitch.
So as it stands now, the slides and jacks will sort of work intermittently, but more often they're just dead. I'll be happy if replacing the pump works, but I'm not convinced. And with so many delays in getting parts nowadays, I hate to do a lot of trial and error if we don't have to.
Any thoughts?
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
JCK
Ohio
Posted: 10/02/21 11:33am Link  |  Quote  |  Print  |  Notify Moderator
If your slides are rack and pinion there electric and your jacks may be electric also. Sure sounds to me like you have a electrical problem . First you need to do some checking with a volt meter what’s the resting voltage after a night of charging let them rest a couple hours and check compare to battery charts that are available on the internet. While your at it check the charging voltage also and compare to what your converter is rated at. Look at your converted and after making sure shore power is disconnected then tighten all the screws on the distribution board both sides. Something going on your batteries are not charging or bad converter. Could also be a bad frame ground or battery ground. Sluggish slides or jacks are almost always a low voltage issue.
2019 GMC Denali 2500 Duramax
2018 Grand Design Imagine 2500 RL
dedmiston
The West
Posted: 10/02/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Everything else is running fine off 12v and the jacks are definitely hydraulic.
It’s a sunny day and the solar is working. Batteries are at 13.8.
Second Chance
Wherever...
Posted: 10/02/21 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
On our Solitude fifth wheel, the leveling system and slides share the hydraulic pump and motor and use switching solenoids (perhaps the "thunk" you're hearing) to control everything.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Seattle Steve
Tucson
Posted: 10/02/21 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Converter problems was my first thought as well. Normally your batteries are charging fine from solar, so you don't notice that the converter isn't working until no solar.
dedmiston
The West
Posted: 10/02/21 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
Rob
Same fluids or is there another reservoir?
CA Traveler
The Western States
Posted: 10/02/21 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
My first thought is your tech is clueless, find someone experienced. Rack and pinion suggests electric. Hydraulic would have 2 hoses per cylinder - 2 for a jack and 2 for each hydraulic ram. He should be able to easily determine what you have.
The thunks are likely a solenoid or heavy relay. Your switches cannot handle the very power draw so they activate the solenoid which has a second heavy wire from the battery.
I would start with a digital voltmeter connected to a clean frame ground (not a wire) to the battery + cable. What is the voltage when the clunk occurs? Continue downstream and you should have close to 0V on the negative wire and 11-12V on the positive wire to the motor.
I'm also wondering if the batteries are wired correctly, one or more reversed. And don't assume new batteries haven't failed, it happens.
2014 Grand Cherokee Overland
Bob
dedmiston
The West
Posted: 10/02/21 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Don’t blame the tech just because I disagree with him.
The underbelly is sealed and there’s no way to see the slide motor without cutting into it.
The only reason I’m skeptical is because the reservoir only supplies the jacks and not the slides as far as I can tell.
trailrider
Idaho Is Full! Don't Move Here!!!
A "tech" could diagnose the problem and fix it. A "parts replacer" thinks it's the hydraulic pump. Your relay/solenoid that clunks is probably on it's way out and isn't sending enough voltage/current to the hydraulic pump motor. The motor or pump could be going bad also. Or a bad ground as suggested above.
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
Posted: 10/04/21 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Not familiar with the system(s) on your trailer, but if other 12V systems work properly and both the jacks and the slides are iffy, tells me they run off the same system or a same relay and that the issue is not downstream at the jacks or slides themselves.
Maybe I just stated the obvious but??
Unfortunately you may have to open stuff up to find the location of the “thump” noise and go from there.
Sorry this probably is of not much help…
2017 Heartland Torque T29
