mharrel
CA
Hoping you guys can help me. Ive got a 2013 class c Coachman on a Ford E450 super duty chassis.
The truck battery, alternator, volt reg have been checked professionally several times this last week at three different battery stores. The battery is dated at 11/17, so it is almost 4 years.
The truck battery will discharge overnight. It will go from the 12.7v to 8.0 or lower over night and the truck will not start in the morning. I have made sure to turn everything in the truck off (radio, cell phone cable, interior lights, key in correct position, etc) and it still does it. I can jump start truck and drive and battery charges ok. I can charge battery back to spec voltage and it will start and run.
While charging yesterday, we noticed a "ticking" sound coming from under the steering wheel area. Could not locate the source of sound. I could hear ticking sound, both if engine was running or off. I tried to pull one fuse at a time to see which circuit would stop the ticking but could not do all the fuses as some were too big for my puller to extract. I disconnected neg terminal and ticking stopped. I have left it disconnected and charged battery. It is holding voltage while disconnected.
So, Im confused. What is drawing down the truck power? This has only started in the last week. Previously, it has been very reliable and worked fine. If I charge the battery and disconnect from truck it will stay charged to spec voltage overnight.
Any thoughts or ideas would be greatly appreciated.
trailrider
Idaho Is Full! Don't Move Here!!!
From The Internet:
A malfunctioning diode in the alternator can create a parasitic drain on a car's battery. Diodes should allow current to pass in only one direction, but a bad diode will keep the charging circuit open even when the engine in not running, allowing the battery to go dead. This often happens overnight.
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
mharrel
CA
thanks trailrider.
so the fix is to r&r the alternator? or can it be checked while on board?
enblethen
Moses Lake, WA
You are talking chassis under your class C motor home?
In that case there is other items.
Do you have electric step? It has some draw.
Carbon dioxide detector, has draw from chassis battery
Charge relay from battery control center could be holding in so you are using power from chassis battery.
Yes, a diode in alternator. It should show up on a proper alternator test.
To test your self, disconnect and insulate the large wire on alternator. If battery stays up, replace alternator.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Gdetrailer
PA
mharrel wrote: thanks trailrider.
If it was the alternator, I doubt you would here a ticking sound coming from under the dash.. Diodes generally when they go bad, short or open, ticking sound would not come from that.
Ticking would mean something like a motor running or a relay opening and closing.
2013 Fords often had wiring harness issues, one real bad one is there is a harness on the driver side which has a connector that the pins get damaged from the vibration caused by applying and releasing your parking brake. Ford decided it was a good idea to solidly wire tie one side of the connector directly to the parking brake assy.. The fix to prevent damage to the connector was to remove the wire tie and tie the connector and cable to another wire harness above the brake assy..
One other wiring harness issue has been moisture getting into several of the wire harness connectors at the rear of the vehicle.. On trucks those connectors are above the spare tire..
It will be difficult to isolate where the drain is coming from, so many over the top complex computerized systems and some fuses are in and around the engine compartment along with inside the cabin..
MEXICOWANDERER
las peƱas, michoacan, mexico
Starting off
Yank the cruise control fuse
Yank the windshield wiper stalk fuse
Yank the main Accessory fuse
mharrel
CA
e.nblethen :
thanks for the help.
yes, it's the chasis (truck) battery not the house battery.
no, no electric stairs
is the carbon dioxide monitor able to disconnect from power to check to see if that is problem?
would the "charge relay" be in the fuse box. it looked like there were a bunch of relays in there.
thanks for your ideas.
Dusty R
Charlotte Michigan 48813
Sort of a fix.
Get a Battery Disconnect Switch, and put it on the engine battery, open it when engine is not being run.
Gdetrailer
PA
mharrel wrote: e.nblethen :
Carbon monoxide/LP gas monitor should be only connected to the "house" battery, not the chassis battery.
If you are talking "charge relay" as the relay to charge your house batteries while driving, that relay would be mounted in the engine compartment not under the dash.
As far as engine charging goes, no relays involved, alternator is directly connected to the batteries as pretty much a industry standard. The diodes in the alternator prevent the alternator from draining the vehicle battery when engine is off.
What you are looking for is items which may have power all the time regardless of engine on or engine off.
in 2013, very few items are directly turned on/off via the keyswitch. Instead many items use Fords "CAN Bus" which is Fords version of a data network.
Good example of this is the factory stereo in that yr, the main connector to the radio does not have any ignition "switched" 12V power. Instead, the radio is turned on/off through the CAN bus data network, the radio gets data from the CAN Bus that tells it to power up or turn off.
The downside to this setup is all it takes is one broken or shorted wire anywhere on the CAN bus network to create a failure of the entire network which may cause modules using the CAN bus to not turn on or off when they are supposed to.
It is that reason why I mentioned the harness connectors at the rear of your vehicle, water intrusion damage is very real on 2011 and up Ford vehicles. One wouldn't think a little water in a connector that far away could cause things to not work correctly, but it does.
It is also the reason I mentioned checking the connector which is attached to the parking brake assy.. The pins break from the wire in that harness connector causing lots of electrical gremlins.
2112
Does it tick about twice a second? My 2011 F150 did that while the ignition was on but not off. My ticking came from the AC blend door motor trying to find its home location. The nylon gear was shot so the motor constantly ran.
Your ticking may be something different.
2013 KZ Durango 2857
