RV.Net Open Roads Forum: Travel Trailers: Why ? trailer jacks so tall ?
 > Why ? trailer jacks so tall ?
wanderingbob
monticeeo, fla
Posted: 10/02/21 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Many complain that they can not open the tailgate on their pickup while hitched to their trailer . Me too ! My jack is ten or eleven inches taller than needs to be ! Probably the same for most of you .
rbpru
North Central Indiana
Posted: 10/02/21 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
The only reason I can think of is the screw jack has to have enough travel. About half of it is used, just getting from the up position to the ground, then you have to raise the trailer.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
capacitor
California
Posted: 10/02/21 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
The size of the jack head can interfere with the tailgate opening. I have a husky and no problem dropping the tailgate. Get a longer ball mount or turn the jack till two holes line up and drill the third hole.
JRscooby
Indepmo
Posted: 10/02/21 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Story is when Abe Lincoln was asked how long a man's legs should be "Long enough to reach the ground".
Look at your rig, side on. The tongue jack must extend far enough to reach the ground, plus enough to lift TV back up to the ride height when MT. Then it still needs to go down another 4 inches or so, to get the coupler clear of ball. Now unless you can get some help from Hermione, that shaft needs to go somewhere when you lift the foot off the ground.
Gdetrailer
PA
Posted: 10/02/21 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Simple, replace the standard jack with a "low profile" jack.
The big downside with low profile jacks is the range of height that they are able to lift, I have seen low profile jacks with as little as 14" lift.
If you have a Tractor Supply store handy, go and see what they have available that might not be as tall. Just be aware that the low profiles will often need extra blocking or a removable foot in order to get enough lift range.
wing_zealot
East of the Mississippi
Posted: 10/02/21 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Get a longer hitch drawbar.
NamMedevac 70
Reno
Posted: 10/03/21 07:02am Link  |  Quote  |  Print  |  Notify Moderator
I never had this problem with a standard electric jack and Equalizer WDH on an 2003 R-Vision Trail Cruiser TT by Monaco Coach. No modifications or extensions were used and the jack was NOT low profile. Maybe I can find the photo. The new
TurnThePage
North ID
Posted: 10/03/21 10:20am Link  |  Quote  |  Print  |  Notify Moderator
It seems like they could mount the tongue jack more rearward. Between the batteries and the propane maybe, leaving lots of room up front.
I used a longer shank that gave me an extra 6" of clearance for the tailgate. Worked perfect for my application, but I can feel the difference when towing. Still well controlled, just not quite as perfect. My truck is a half ton and my trailer is 24' long and weighs 6300 - 6500 lbs.
2015 Ram 1500
2004 Pioneer 18T6
wing_zealot
Posted: 10/03/21 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
How does that help the OP? His hits.
NamMedevac 70
Reno
Posted: 10/03/21 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Again NN you must be really bored or jea. I was thinking he may have a newer trailer with a short tongue or the placement of the jack on the frame made a difference and I am looking for photo of my setup for his comparison. I am also curious about his predicament since I have not encountered it. You are really s You need to go fishing or get a life OM. This is not your first time to
* This post was edited 10/03/21 01:22pm by NamMedevac 70 *
