RV.Net Open Roads Forum: Travel Trailers: Why ? trailer jacks so tall ?
 > Why ? trailer jacks so tall ?
deltabravo
Spokane, WA
Posted: 10/04/21 06:51am Link  |  Quote  |  Print  |  Notify Moderator
NamMedevac 70 wrote:
I was thinking he may have a newer trailer with a short tongue or the placement of the jack on the frame made a difference
Nope.
Jacks have been in the same place on the coupler since pretty much the invention of trailer jacks. All trailers I've seen, the coupler is where the jack attaches, which means trailer tongue length is an irrelevant factor in the equation.
The reason a tailgate hits a jack is because tailgates (and overall bed height) are taller on some trucks. The receiver hitch might be tucked further under the bumper and some trucks, reducing the distance between jack and the back of the truck.
* This post was edited 10/04/21 05:39pm by deltabravo *
CavemanCharlie
Storden,MN
Posted: 10/04/21 10:01am Link  |  Quote  |  Print  |  Notify Moderator
wanderingbob wrote:
Many complain that they can not open the tailgate on their pickup while hitched to their trailer . Me too ! My jack is ten or eleven inches taller than needs to be ! Probably the same for most of you .
For you it seems that you don't have to crank the jack that far. But, for some of us we need the extra screw that is that taller jack. I agree that it is a pain opening the tailgate with that jack in the way. Plus, the cushion part of the handle fell off of my jack and now I have a scratch on the tailgate where it hits the jack . They do make tailgates with a dip in the middle that you can purchase if you want.
deltabravo
Spokane, WA
Posted: 10/04/21 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Those are designed for 5th wheel haulers, and most I've seen are vented.
Useless if you have a canopy on the truck.
Longer drawbar (stinger) solves the problem.
GrandpaKip
Flat Rock
Posted: 10/05/21 08:01am Link  |  Quote  |  Print  |  Notify Moderator
Have you tried turning it 90 degrees?
I did that and it worked fine.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Posted: 10/05/21 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve only been towing trailers since I was old enough to drive in 1988, but I’m not sure I’ve ever had a trailer that the top of the jack wasn’t at least as tall as the tailgate of the truck, when the tailgate was folded down. And that seems like a pretty consistent dimension across the years and brands of trucks.
Even my current rig which has a 6” lift and 37s and generally a 8-10” drop ? hitch, the jacks on the few trailers Ive pulled are still taller than the tailgate when it’s folded down and the trailer is hooked up reasonably level.
Seems like one of those petty first world problems to me.
* This post was edited 10/05/21 05:54pm by Grit dog *
2017 Heartland Torque T29
JJnLilly
Ohio
Posted: 10/10/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Having a similar tailgate issue since moving back to a trailer from the fifth wheel. No problem if I left the open fifth wheel tailgate on but don't want to do that since I am having to carry more things in the bed.
Only need about an inch to clear the switches on the jack so maybe a longer hitch bar is the answer. But they are pretty pricey just to gain a couple of inches.
2007 Ram 2500 QC CTD
2020 Passport GT 2210
hussbuss
home
Posted: 10/14/21 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
You can take the hitch bar to a machine shop and have a new hole drilled in the bar if you only need an inch. Also most rv shops will have an assortment of used hitch bars you might be able to trade for yours. we did that for my daughters TT. Dealer said, find one that works and leave yours. Even trade.
