RV.Net Open Roads Forum: Tech Issues: Battery Problem
 > Battery Problem
jgrimes
Kalispell, MT
Posted: 10/02/21 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2 6V golf cart batteries in my 5er. Batteries are old and due to be replaced. When I checked the water level, the level was a little low but it was obvious one of the batteries has cooked the water and overflowed. Can I assume this simply means the batteries need replaced? Or could it mean the converter is faulty? Electrical is not my strong part. Any help would be appreciated.
pianotuna
Regina, SK, Canada
Posted: 10/02/21 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
jgrimes, what is the make and model of the converter?
Regards, Don
jgrimes
Kalispell, MT
Posted: 10/02/21 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
It's a WFCO Model WF8930/50. It's in my 2014 Solitude.
pianotuna
Regina, SK, Canada
Posted: 10/03/21 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Not a wonderful converter. Consider an upgrade.
jgrimes
Kalispell, MT
Posted: 10/04/21 09:26am Link  |  Quote  |  Print  |  Notify Moderator
I have ordered the Progressive Dynamics Model PD9260-cv. My trailer operates on 50 amps. I now see the converter is 60 amps. Will this be a problem? Ordered it on Amazon.
sparkydave
Macedonia, OH
Posted: 10/04/21 10:08am Link  |  Quote  |  Print  |  Notify Moderator
The 60 amps refers to the current it can deliver on the 12 volt DC side. Not the same thing as the 50 amp shore power connection on the AC side.
pianotuna
Regina, SK, Canada
Posted: 10/04/21 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
No problem at all.
jgrimes
Kalispell, MT
Posted: 10/05/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Thx for the help on the converter. I am replacing my 2 6 volt golf cart batteries. Apparently new ones are hard to find. Local guys has group 31 AGM batteries available. Be says one AGM group 31 will give me the same capacity as two 6 volt batteries. Does this sound right?
Boon Docker
Posted: 10/05/21 11:16am Link  |  Quote  |  Print  |  Notify Moderator
No, one GR 31 will give you 1/2 the amount of amp hours compared to 2 GC2 batteries.
pianotuna
Regina, SK, Canada
Posted: 10/05/21 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
jgrimes,
What Boon Docker said.
 > Battery Problem
