RV.Net Open Roads Forum: Regrets with 19.5" tires? Places you havent been able to go?
 > Regrets with 19.5" tires? Places you havent been able to go?
Toximus
WI
Posted: 10/03/21 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at purchasing a new truck and a medium size truck camper (likely a Lance 960).
  • 75% of the miles will be hauling a 20' enclosed trailer with a rock crawler or UTV inside to camp and trails.
  • 15% of the miles will be just the truck and camper on shorter road trips without the trailer.
  • 10% of the miles will be around our house doing yard work or driving to town to grab car parts or lumber. I'm not too concerned about ride comfort for this since it's not a daily driver.
I need to make it to up mountains with dirt/gravel roads (think CO) to get to camp, park off the road at places like Glamis, and will be driving on highways and some back roads to my house through winter when it obviously can snow. After rain in the Spring and Fall I also don't want to get stuck on soft ground.
Does anyone else do similar travel with 19.5" tires? Instead of an F450 do you recommend a F350 or Ram 3500 with 17" tires?
Posted: 10/03/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
If your comparing to a F450, are you planning on a 350/3500 dually or srw ?
If dually, you have no need for 19.5s at all
If srw then makes sense as your rears will be at max with OEM tires and wheels
* This post was edited 10/03/21 04:17pm by Grit dog *
2017 Heartland Torque T29
jimh425
Western MT
Posted: 10/03/21 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
I haven’t had any problems going where I want to go. But, you might want to go somewhere different.
F450s have 4.30 gears by default which will hurt your MPG compared to a F350. 19.5s can’t be aired down due to the type of beads they have. I bought a F450 because I wanted the tougher tires, better brakes, and better turning radius of the F450 and to future proof if I ever wanted a large fifth wheel.
It sounds like from your description, you’d be better off with a F350 DRW. You have much more options for tires with 17s, and like I said, you can air them down if needed.
Kayteg1
California > Nevada
Posted: 10/03/21 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds to me that you are trying to avoid DRW and do 19.5' wheel conversion + suspension reinforcement to make it working with camper and trailer.
I bought DRW and never had the dilemma, but I read that several members who spend big money on SRW suspension upgrades, eventually ended in buying DRW.
19.5 might be a help, but they are not substitute.
specta
utah
Posted: 10/03/21 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I think new F-250s and 350s come with 18" wheels.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
jimh425
Western MT
Posted: 10/03/21 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
That’s why I was thinking he’s trying to decide between a F350 DRW and F450 DRW.
Posted: 10/03/21 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Packers won so OP is probably indisposed for a while!
Bedlam
PNW
Posted: 10/03/21 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
19.5's have plenty of traction tread but do not have flotation. If you are in deep snow or soft sand, LT tires are better. I am on my second truck now with 19.5's and know the limitations but will not give up the durability and load carrying ability.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
mbloof
Beaverton, OR
Posted: 10/04/21 11:34am Link  |  Quote  |  Print  |  Notify Moderator
I switched over to 19.5's in 2014. While I don't drive on beaches or have been caught in the snow there are a number of options with mountain/snowflake available in the 19.5 sizes.
I like the peace of mind that my tires are not the 'weakest link' and I'll likely replace them due to age rather then wearing them out.
- Mark0.
Bedlam
PNW
Posted: 10/04/21 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I just received a seven new 245/70r19.5 Toyo's to replace my 7 year old OEM tires. After 65k miles, the Continental's still have healthy tread but are being replaced due to age. I never had to use the spare, but it is also getting replaced.
