RV.Net Open Roads Forum: Fifth-Wheels: Solar panel mounting; screws or toggle bolts?
 > Solar panel mounting; screws or toggle bolts?
Wet Coast
Shawnigan Lake on sunny Vancouver Island
Posted: 10/03/21 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hello Brain Trust,
I am about to add some more solar to the roof. When I did my first panel, I used toggle bolts and just went through the plywood. So the holes were a little large; that's what Dicor is for!
My first 6' x 3' panel has four brackets and hasn't blown off in over 20,000 miles of travel.
I am using 4" x 2" aluminum angle. My question to you all is can I just use 4 #12 x 1" screws on each bracket, rather than the bulldozer approach of the toggle bolts and still have enough holding power?
What is everyone else doing for amounting method?
Thanks in advance, Rick
04 3500 4X4 Auto Cummins QC
Onboard air, Air bags, Pac Brake
05 Cougar 244EFS, Flexair Pin Box, Dexter Equalizers
6x240AH 6v, 400w PV, 2000w Xantrex, 3500w Genset
VA7RKC Advanced Amateur Radio Operator
Everything runs on smoke, don't let the smoke out
TXiceman
Full Time RVer
Posted: 10/03/21 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
I would just use lag bolts and Dicor the heck out of the bolts and brackets. Put butyl tale under the bracket before you bolt them down.
Ken
Amateur Radio Operator.
Ed_Gee
Central Oregon coast
Posted: 10/03/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Frankly, the modern thing to do is use 3M VHB 4950 double sided tape and stop putting holes in your roof.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Near Bishop, California
Posted: 10/03/21 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Dicor over screws into 3/8 plywood has held up well for me. Tape is a good idea except I have a rubber roof.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
bighatnohorse
Gig Harbor - Cave Creek
Posted: 10/03/21 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Go to YouTube and search for well nuts.
I've used well nuts on two campers and consider them the best way to attach solar panels.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
EgorKC
Kansas
Posted: 10/03/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
If the VHB tape is going over a rubber roof the mechanical connection is only as strong as the adhesive bond between rubber and wood. The VHB will likely Never fail. However, the wind uplift could cause the rubber roof adhesive to fail. We have all seen that trailer coming down the opposite side of the highway with the giant air bubble beneath. I would not risk having an 8 square foot kite peeling my roof off. Could be a problem for traffic behind too.
Greg
You cannot stop growing old but you don't have to grow up. ">
Chef/Pilot
DW/Navigator
2 Sons, 1 DIL, 3 Grandsons, 1 Granddaughter. Boz the cat">
2012 F350 XLT 6.7 Powerstroke 4X4 SWD Crewcab.
2012 Wildcat 313RE-OK
dieseltruckdriver
Black Hills of SD
Posted: 10/03/21 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
On my roof I put down a strip of Eternabond under the "feet" of the solar panels, then put down some Dicor and set the "feet" down and screw that down to the roof.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
goducks10
There
Posted: 10/04/21 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Ken
x2, exactly what I did. 3 seasons and no leaks.
jdc1
Rescue, Ca
Posted: 10/04/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
I'd try to get at least the most forward screws/bolts into a roof truss. They will be the parts that have the most uplift.
Ed_Gee
Posted: 10/04/21 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Greg
Very True. The OP did not say he had a rubber roof so I didn't know.
