RV.Net Open Roads Forum: Technology Corner: Dish Upgrade
 > Dish Upgrade
Posted: 10/03/21 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
I'm ready to upgrade my MP1 satellite dish to something a little more user friendly. I'm finding myself manually moving from 110 to 119 more than I use to and it's becoming a pain. Plus the MP1 is SD only. It's time to move into the 21st century.
After comparing features, price and reading reviews I'm considering the Winegard Pathway X2 and Wally Receiver Bundle on Amazon. I plan to add a second Wally for the bedroom.
Anyone have any 1st hand issues or problems with this setup?
I mounted my MP1 on a piece of plywood to help stabilize it. Can I do the the same with the Pathway? I really don't want to mess with a tripod if I can avoid it.
The King Tailgater seems to be similar but the reviews I read are not as good.
Thanks for your input
Dave
2013 KZ Durango 2857
Dutch_12078
Winters south, summers north
Posted: 10/03/21 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
The Pathway X2 is the better choice since it receives both the western arc satellites and the full set of eastern arc sats. While nothing electro-mechanical is infallible, I see very few complaints about the X2 in the various RV forums I frequent. The biggest complaint seems to be that the larger size takes up a little more storage space than the others. Given that the larger dish means less rain fade and stronger signals, I think that's a fair trade off. The only issue I've ever been asked to fix related to an X2 was simply a failed coax connector, a 5 minute fix.
Dutch
2001 GBM Landau 34' Class A
lryrob9301
Mid-Atlantic
Posted: 10/03/21 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
I've had my Pathway X2 since 2011 and used it from Halifax NS to San Diego CA. It's been through many thunder storms, a few snow storms, a hail storm in Del Rio TX, and still works like new. Yes it's bigger to store but worth every bit of space. There is no better portable antenna for DISH Network. Yes you can mount it on plywood. The King Tailgater is not even close in durability and the ability to receive the full DISH Eastern Arc AND Western Arc satellite groups.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
2112
Posted: 10/04/21 04:28am Link  |  Quote  |  Print  |  Notify Moderator
I wasn't thinking about size. I need to make sure I can store it before I squeeze the trigger
Thanks
LouLawrence
Traveling the US!
Posted: 10/04/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
The MP1 is not SD only with Dish Network.
The Pathway X2 is MUCH larger than the MP1 but that's also one of the reasons it's such a good choice.
If you plan to hook up 2 receivers, one will be fully functional and the 2nd will be a slave being able to only watch channels that are coming from the same satellite the 1st receiver is using.
2112
Posted: 10/04/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
That's probably true. My 322 receiver dictates I'm watching SD.
I didn't realize how big it is until I took a tape measure to my basement. I can get it in but it's going to eat up some storage real estate. We can live with that. We haven't used the guest house (tent, sleeping bag and air mattress) in some time so that can go to free up space.
Regardless, unless someone can point me to a better opinion I'll pull the trigger on the X2. I'm looking for auto setup with 2 tv capability. Eastern arc is a bonus but not required, or should it be?
Thanks
goducks10
There
Posted: 10/04/21 09:43am Link  |  Quote  |  Print  |  Notify Moderator
I've had a Pathway X2 for 7+ years. It works great but it's big and sometimes awkward. In the time we've owned it I bet I could count on one hand how many other X2's we've seen. When it finally does quit working I'll be going to a smaller satellite.
2112
Posted: 10/04/21 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the testimonial. Your last sentence spoke volumes to me. I can see it being awkward as well. Getting it in and out of the basement looks to be a chore.
Maybe I need to rethink this. I got to the point to where I hate pulling out the MP1. The X2 may suffer the same
Dutch_12078
Posted: 10/04/21 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Having both eastern and western arc capabilities expands your aiming options significantly if you often use sites with much tree cover. Having both arcs available has meant we've been on a couple of hundred different sites since 2010 and have never not had sat signals available from one arc or the other.
Sandia Man
Rio Rancho, NM
Posted: 10/04/21 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
We have always purchased and manually set up the same antenna mounted at home when RVing, been doing it for over a couple of decades with both Directv and Dish. Took longer to get antenna out of basement storage and unravel coax than actually locking in satellites, all in all maybe 10 minutes to access all the channels on two vip receivers without restrictions or delay.
Our current rig is a class a and the previous owner threw in a couple of King tailgator pro 2 domes, one for Dish and the other for Directv. Having heard generally bad things about automated sat. acquiring domes I continued to bring along our manually set up antenna. Heard domes were slow and often had problems attaining all satellites among other minor issues.
Never worried about my manual satellite setup at a campground, didn't want our King tailgator growing legs and walking off. I purchased a roof mount that allowed easy removal of dome should trees or other obstruction require repositioning to acquire satellites. Saving space on storing dome, tripod, and excess coax were other positives to look forward to with roof mounted system.
To my surprise the King tailgator has performed flawlessly, easily attaining satellites without issue, even when RVing in a dense ponderosa pine forest. Have never had a reason to unclip from roof mount and reposition, it is always ready to go by the time we finish setting up rig upon arrival. Like any dome it is slower than residential antenna, couple of seconds if channel is on another satellite.
Can't speak on any other brand of automated satellite acquiring domes, again I never thought they were reliable enough to purchase from all that I've heard. We primarily do most of our RVing in the mountain west and SW regions of the country and never had reason to use eastern arc, we are satisfied with King tailgator performance and can always use manual setup if needed for eastern arc.
 > Dish Upgrade
