RV.Net Open Roads Forum: Mount 100lb mini-split condenser to rear wall?
 > Mount 100lb mini-split condenser to rear wall?
SlowBro
Posted: 10/04/21 04:56am Link  |  Quote  |  Print  |  Notify Moderator
I have a Coachmen class A and want to mount a 100lb mini-split to the rear wall. Is this too much weight? I know some people use a hitch carrier but ours is occupied. And this RV has no square bumper to put mounts on.
I would use one of these wall mount kits. Maybe this exact model, maybe one like it.
https://www.homedepot.com/p/DuctlessAire........tioners-and-Heat-Pumps-BPC-3LP/205886666
* This post was last edited 10/04/21 06:42am by SlowBro *   View edit history
2010 Coachmen Mirada 34BH, class A, 34.75' long, GVWR 22,000 lbs.
God bless!
valhalla360
No paticular place.
Posted: 10/04/21 07:35am Link  |  Quote  |  Print  |  Notify Moderator
What's occupying your hitch carrier?
Might be able to get a shop to weld up something that will hold the air/con and the bikes (?).
I wouldn't trust the walls. In a house, they drill into the 2x4 studs. RVs don't have anything like that.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
bgum
South Louisiana
Posted: 10/04/21 07:55am Link  |  Quote  |  Print  |  Notify Moderator
I would advise against doing so.
jdc1
Rescue, Ca
Posted: 10/04/21 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Maybe if you through bolted the brackets and run steel plates 4' long across the interior wall to spread the load across 4 studs. Yea....that ain't gonna happen....
gbopp
The Keystone State
Posted: 10/04/21 09:35am Link  |  Quote  |  Print  |  Notify Moderator
It will be 100 pounds when it's stationary. When it's bouncing down the road it will increase.
Those brackets will probably tear out of the wall.
SlowBro
Posted: 10/04/21 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone, I'll figure out a plan B
Near DVNP, California
Posted: 10/04/21 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Without re-enforcement, your plan scars me!
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
jdc1
Rescue, Ca
Posted: 10/04/21 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I won't be driving behind him.
deltabravo
Spokane, WA
Posted: 10/04/21 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto
It would look really bad, and no one would buy it when you decide to sell it.
This style of heat pump is a far nicer looking option and won't destroy the rear wall (or resale value) of your RV
Cummins12V98
on the road
Posted: 10/04/21 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
I have a friend that mounted his to his rear bumper. He was more than impressed with the units performance.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
