RV.Net Open Roads Forum: Tech Issues: Rooftop material
 > Rooftop material
MarcSnyder
Montreal
Posted: 10/04/21 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Would a 2002 Four Winds Majestic have a TPO or an EPDM rooftop?
That stands for Thermoplastic Polyolefin and Ethylene Propylene Diene Terpolymer, for those wondering. Two different types of single-ply roofing materials.
Also, don't tell me to look at my owner's manual: I already have ;-)
Thanks in advance.
TurnThePage
North ID
Posted: 10/04/21 08:24am Link  |  Quote  |  Print  |  Notify Moderator
You can remove the inner trim for one of the vents which will allow you to see the edges of the material, where it was cut to fit the opening. EPDM will be white on top, and black on the bottom.
2015 Ram 1500
2004 Pioneer 18T6
IAMICHABOD
Sunny So Cal
Posted: 10/04/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Here is a surefire way to tell,watch This Video
Welcome to the Forum,being new here you may not have seen This Thread
There are many Majestic owners there and they may be of help to you on any other questions that you might have.
Stop on by and join up with more 140 Former Rental Owners.
Former El Monte RV Rental
Buying A Rental Class C
dougrainer
Carrolton, Texas
Posted: 10/04/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
EPDM is a 40 mil thick black on white roofing material which is a bit heavier due to the higher concentration of rubber. TPO is lighter due to a higher concentration of synthetic material in a 30 mil thickness, and it is a white on white roofing material. Both products are of the highest quality and come with similar warranties from the manufacturer - over 10 years for each one.
TPO roofs negative may be as they age, they become less flexible and can actually crack open. This is the main factor that limits their lifespan. But with the 15 year manufacture warranty this is not a major issue for most buyers. Since TPO is a slightly cheaper option, it's very popular with todays RV owner.
EPDM rubber only negative including the absorbing sunlight and has occasionally seen moisture leakage. It's a strong material that tends to last a bit longer and is durable especially with a hail storm..
In conclusion, both products are very high quality and will help protect your RV roof greatly. The EPDM rubber is a bit thicker, but the TPO is more reflective. We have a chart below that breaks down both products. Doug
Flan
NE
Posted: 10/04/21 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Do they both get chalky? If I walk or kneel on mine, I become very white quickly.
Heartland Prowler 27LX
19 Ram CTD 2500
BFL13
Victoria, BC
Posted: 10/04/21 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
If you intend to use the product, Liquid Rubber (LR) on it, you must know if it is TPO, which LR will not stick to well (see their instructions). That product is for EPDM. Even with that you still need to use their special prep stuff, which greatly helps the LR stick to the EPDM.
I used LR on my 1991 which had some kind of deteriorated white on both sides "rubber" on it, that I took to be TPO. However some info says TPO came out in the early 90s, so I don't know if a 1991 RV would have it. Anyway the LR ( just that with no EPDM prep stuff) stuck so I got away with it.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
TurnThePage
North ID
Posted: 10/05/21 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Chalky is most likely EPDM. The white part sluffs off over time.
MarcSnyder
Montreal
Posted: 10/05/21 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone. And to answer BFL13's comment: that's exactly why I'm asking :-)
 > Rooftop material
