RV.Net Open Roads Forum: General RVing Issues: landing gear issue
 > landing gear issue
walker111
se calgary
Posted: 10/04/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Hi all
Own a 2014 Voltage 3305. This past weekend the landing gear seemed to cause me problems. When I was hooking up sunday to leave, the gear was very slow and would only run about 3-5 seconds and then stop all together. I would wait a minute and it would run 3-5 again and stop.
I ran the on board genset, I plugged in . Nothing helped. Batteries are fully charged. Was able to get the trailer up enough to hook on and then same issue at my storage facility.
Think the motor is done?? It has been slow for a while but not like this . Is the manual overide at the top pf the leg on the driver side of trailer?
Thanks for any response.
dedmiston
The West
Posted: 10/04/21 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Sorry to hear about this.
What kind of landing gear do you have? Electric w/motor, hydraulic, etc.?
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
walker111
se calgary
Posted: 10/04/21 10:16am Link  |  Quote  |  Print  |  Notify Moderator
It is electric motor. I will go to storage today to troubleshoot. I will look for an inline fuse and swap out. The motor works but very weak then stops as I described so the fuse is working but will check it out.
Thanks for reply
fj12ryder
Platte City, MO
Posted: 10/04/21 11:16am Link  |  Quote  |  Print  |  Notify Moderator
If the leg motor works at all, it's unlikely to be the fuse. Our 2010 Fuzion 383 leg motor finally bit the big one. It never worked very quickly, and just kept getting slower and slower. I replaced the motor/legs with the Bulldog system with separate motors for each leg. An excellent solution IMO. The legs no longer struggled. The trailer is gone but the Bulldog system was great.
Howard and Peggy
"Don't Panic"
walker111
se calgary
Posted: 10/04/21 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
I doubt fuse also for that reason. Mine has always been slow for raising the trailer. Could need a new motor.
MFL
Midwest
Posted: 10/04/21 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Have you ever lubed the legs (screw drive)? When mine run slower, I added a couple lever strokes to each one, per manufacturer recommendation. Doing this perked them right up, motor run faster. Mine has zerks on the legs about 8"s or so from top of leg.
If yours need lubing, it may add extra load to motor, causing solenoid/breaker to shutdown, and reset.
Jerry
walker111
se calgary
Posted: 10/04/21 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I will go to storage compound today or tomorrow and update
Thanks for info Jerry
JRscooby
Indepmo
Posted: 10/04/21 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Also make sure all connections are clean (ground too) If the wires are marginal, a weak connection can reduce voltage for a motor to run slow. And low voltage can kill a DC motor in short time.
Just for snots and grins, use a good pair of jumper cables to by-pass all the factory wiring. Bet the motor runs much faster than new.
schlep1967
Harrisburg, PA
Posted: 10/05/21 05:20am Link  |  Quote  |  Print  |  Notify Moderator
If it's like mine there should be 2 wire nuts about 6 inches from the motor. Take those off and separate the wires. Hook your jumper cables directly to those wires and your trailer battery. Positive to one wire negative to the other. It will spark when hooking up. To go the other direction switch the positive and negative.
This will tell you if the motor is the problem. If it runs strong with the jumper cables the motor is fine and either lubrication or poor wiring is your issue.
Mine started blowing fuses when it ran slow. My guess is you don't have a fuse inline or it would be blowing. It sounds more like the motor is hitting it's heat maximum and shutting down. Definitely look up how to lube the landing gear and check the wiring connections.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
JRscooby
Indepmo
Posted: 10/05/21 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Warning! Yes, it will make a spark. Better to hook the cables to the battery, then to the wires. It will still spark, but the spark not be right at the battery. Much less chance of a explosion.
