SUMRX4
VA
I guess everyone is different LOL. I have never stayed at a CG that didn’t have water available. Not that I’m against it, just none that I’m aware of around me for boondocking. As far as traveling we usually camp within a couple hours of the house so no need for stopping along the way. And if we do I just always pulled I to a convenience store or fast food joint.
So the tank on the new rig was filled for the PDI. If I use that and drain it, then say two years down the road i need it, I can just rinse, sanitize, and I’m good to go?
SAR Tracker
Central Oregon
We also use ours for a "bug out trailer" since we live in a high fire danger area. Full water, fuel, batteries on charge, everything ready to go if we have to evac. Once fire season is over, I'll drain for the winter, and move freezable stuff into the house.
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
RoyF
Fayetteville Arkansas
I like to use water from the fresh tank and top it up as needed, which is usually about every third day. That means that water in the fresh tank is always quite fresh.
If the RV has been sitting in storage for a few weeks, then at the first campsite I drain the fresh tank (hooking to camp water while it drains) and refill it. (This assumes that the first campsite is in an area where there is an ample supply of water.)
RRinNFla
Northeast Florida
All of the reasons above, plus if we need to use the “rest” room and there are no facilities we can use our own. I don’t like to fill it before leaving since 40 gallons of fresh water weighs almost 300 lbs. Most campgrounds without water have a fresh water fill station unless they have been shut down for winter.
I also try to find out in advance if the campsite includes water hookup.
Richard
2015 Prime Time Crusader 295RLT
2008 Ford F250 V10 (Gas), EC, SB, 4X4
Timmo!
Far away from this WOKE website!!!!!!!!!!!!!!!!!!!
If "camping" involves parking one's rig on asphalt with full services (including wifi), then "why should I use the fresh water tank" is a valid question.
If "camping" involves parking one's rig far away from a water source, then....
My Nash's water tank is under the gaucho bed located at the very front of the TT, and when I run empty, the tongue weight falls below 15%, but increases to around 15% when tank is full.
To each is own, I listen to jazz (Artie Shaw), you may listen to Kenny G. Who is wrong? (nobody).
CharlesinGA
South of Atlanta, Georgia
valhalla360 wrote: As mentioned, if you never plan to use it...who cares.
That said, we use the tank and pump even on full hookup. Had an experience on our boat many years ago, heard a slight hissing sound late at night. Searched it out and found the city water had sprung a pinhole leak. If it hadn't been dead silent, it would have continued for hours or days without us noticing.
Running off the water tank with the pump, if there is a small leak, we will hear the pump kick over periodically alerting us that there is an issue. The RV may not sink but the floors can certainly rot out.
Boats sink when they fill up with water, rv's just get totaled.
Co-worker took his neice/nephew (don't remember the exact details of who they were) with him camping. they used the shower while on city water, shut off the water at the shower head, which leaves it dribbling by design to keep hot water flowing, and to alert you the faucets are on. Well, he failed to follow after them and check that all was properly turned off, and they went to bed only to wake up to an RV standing in water inside. The gray tank had overfilled and the shower pan filled up and overflowed. insurance totaled the trailer.
I do not hook up to city water, I fill the tank and use the pump, and turn the pump off when not using it. I turn the water heater off when not using it, also.
I too listen for the pump cycling when it should not, and that is the clue I should go investigating for a leak or a leaking check valve in the pump.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
toedtoes
California
Obviously the one listening to Kenny G.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
dedmiston
Coast to Coast
SAR Tracker wrote: We also use ours for a "bug out trailer" since we live in a high fire danger area. Full water, fuel, batteries on charge, everything ready to go if we have to evac. Once fire season is over, I'll drain for the winter, and move freezable stuff into the house.
Same here. If fires or earthquakes kill our home services, we'll turn to the RV as our Plan B. The fresh water is filled and the batteries are charging with solar.
Toys:
- 18 Can Am Maverick x3
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
Michelle.S
Western NY till fall, then Sebring, FL
All I can say is: If you don't put water in the Fresh Water Tank, you won't be camping at some of the Beautiful State Park CGs that we visit, as may State Parks in numerous Cities don't have Full Hook-ups.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Lantley
Ellicott City, Maryland
Michelle.S wrote: All I can say is: If you don't put water in the Fresh Water Tank, you won't be camping at some of the Beautiful State Park CGs that we visit, as may State Parks in numerous Cities don't have Full Hook-ups.
That sort of my point. But if your happy with what your doing and FHU is what you seek. There is nothing wrong with that.
The main reason to use your tank is that all parks do not have running water at the site.
There are lots of fantastic sites with no running water.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
