RV.Net Open Roads Forum: Tech Issues: Which inverter?
 > Which inverter?
pasusan
Northernmost PA
Posted: 10/06/21 05:13am Link  |  Quote  |  Print  |  Notify Moderator
In our Roadtrek (Class B) we have an inverter that is used just to run the TV and the DVD player. We think it wrecked the TV. When I put our electrical checker on it there were just 101 volts and there was another message about open neutral.
We're looking to replace it with a new inverter - we know nothing about them and I do remember reading here about pure sine wave or something. [emoticon]
So - what size do we need for just those 2 items - how many watts - and should it be a pure sine wave one?
"I'm out here to enjoy nature -- don't talk to me about the environment!" ~Denny Crane
Susan & Ben
2004 Roadtrek 170 for quick getaways
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub for longer trips
Trip Pics
Near DVNP, California
Posted: 10/06/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Pure sine wave is the safest route and I’d suggest a 300 watt inverter for a TV and DVD if you don’t want look up their individual power needs.
This one has worked well for me for over a year — BESTEK 300Watt Pure Sine Wave Power Inverter Car Adapter DC 12V to AC 110V with 4.2A Dual…Amazon $50.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
theoldwizard1
SE MI
Posted: 10/06/21 07:39am Link  |  Quote  |  Print  |  Notify Moderator
You DEFINITELY. Want a pure sine wave inverter. They cost a bit more, but are worth it. Lots of brands too choose from.
If all you are going to use it for is the DVD and the TV and maybe a laptop charger, 300W - 500W is plenty.
time2roll
Posted: 10/06/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
101 volts is probably due to MSW and is normal. Open neutral is also normal and will not hurt a thing. Most tvs have a brick to supply lower DC to the tv. Have seen some things run hot on MSW although for this it should not be an issue. Signal interference might be a bigger trouble but maybe not with digital signals today.
Anyway I recommend a 200 or 400 watt Go Power sine wave inverter.
https://gpelectric.com/products/400-watt-industrial-pure-sine-wave-inverter/
675w Solar pictures back up
pasusan
Northernmost PA
Posted: 10/06/21 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input guys! Will look into a new one 300 - 500 watts...
Fisherman
Angus, Ontario, Canada
Posted: 10/06/21 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
I've had one of these for about 10 years now to power the TV and satellite receiver. Simple install and no issues. https://gpelectric.com/products/300-watt-pure-sine-wave-inverter/
deltabravo
Spokane, WA
Posted: 10/06/21 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
If the inverter produces a modified sine wave (MSW), you need a high quality volt meter that will measure TRUE RMS voltage. A run of the mill volt meter will always read MSW voltage as "low voltage"
I always use PSW (Pure Sine Wave) inverters in my recent RVs.
 > Which inverter?
