RV.Net Open Roads Forum: Tech Issues: blowing a 20a and 30a fuse instantly
 > blowing a 20a and 30a fuse instantly
blaczero
Posted: 10/06/21 06:27am Link  |  Quote  |  Print  |  Notify Moderator
hey guys, I plug in a cigarette lighter 200w inverter into this...
https://www.amazon.com/gp/product/B01MTBXHEV
and it immediatly blows a 20a or 30a fuse. I wired this up with 12awg.
by my math, it should be drawing nowhere near 30a
the back of the inverter says 200w peak 150w sustained. Nothing is plugged into the inverter when I plug it in, and it works in my truck fine.
Any ideas?
wanderingaimlessly
Buggs Island lake
Posted: 10/06/21 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like plugging something into the outlet is causing it to short internally. Try plugging something else into it, to see if it instantly trips.
blaczero
Posted: 10/06/21 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Plugged a USB charger into cigarette port, works fine
wborst
North Carolina
Posted: 10/06/21 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Are you sure that the outlet is wired correctly? Another possibility is that the inverter has a large capacitor that takes a large surge current to get charged.
Brenda, Bill
Our little dog Madison has crossed the Rainbow Bridge
2003 Newmar Mountain Aire 40ft. Spartan chassis
400 hp Cummins ISL
lryrob9301
Mid-Atlantic
Posted: 10/06/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Check your wiring, I think you have something wrong.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
Gdetrailer
PA
Posted: 10/06/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Recheck the wiring to the cig port, it still can be reversed and a plug in USB charger still work. Plug in power port USB chargers may have the ability to operate with reversed polarity since they could be used in older vehicles with a positive ground.
Your inverter however may not work at all with reverse polarity and may have a reverse polarity diode which acts like a short when reverse polarity happens..
Looking at the back of your power center it is easy to switch the pos and negative wires although this one I picked does have pos (+) and neg (-) markings.
You need to ensure the center connection inside the power port is correctly connected to the positive of your 12V system.
You can verify the correct polarity with using a DVM set to volt meter if you have one by touching the red lead to the center of the port and the black lead to any 12V ground. The voltage on the DVM should read positive and should not indicate (-).
blaczero
Posted: 10/06/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Thanks!!!
Every bronze connector on the panel is ground, except the cigarette lighter. I had the wires on wrong!
Good info on the multimeter, I had tested it but didn't know which should be + (side or all the way in).
Gdetrailer
PA
Posted: 10/06/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
blaczero wrote:
Thanks!!!
Excellent!
[emoticon]
I had thought about mentioning the brass color may be positive which would typically follow other electrical guidelines but was concerned not all were marked that way..
Max fuse size also should be selected to protect the wire.
12Ga = 20A fuse..
10Ga = 30A fuse..
While there may be a few exceptions to that rule, it is very wise to follow typical recommended fusing sizes for the wire size in use. You really want the fuse/breaker to pop before the wire over heats and causes a fire.
Just be aware 20A at 13.8V is 276W max your inverter will be able to supply. Might handle a quick surge above that before fuse blows but that should be fine.
Posted: 10/06/21 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Blows both a 20 and 30 amp fuse instantly.
200 watts of inverter is 20 amps. the starting surge shoudl pop a 20.
Not sure how big the starting surge is but popping a 30 is not beyond belief.
I"d hard wire teh thing via a 40 using at least 10ga or 8ga wires. or even 4ga (battery cable) and keep 'em short.
blaczero
Posted: 10/07/21 06:14am Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer wrote:
blaczero wrote:
Thanks!!!
Excellent!
[emoticon]
12Ga = 20A fuse..
10Ga = 30A fuse..
Thanks to you and the others for the feedback. Learning something every day here.
The panel is in and working great, one more step toward everything on DC
