RV.Net Open Roads Forum: Fifth-Wheels: Fresh water tank
 > Fresh water tank
Diamond c
West ky
Posted: 10/06/21 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
We just bought a 2021 Montana. We are on our first trip in it and I noticed that the fresh water tank is showing 1/3 full. I haven’t put anything in it but may have inadvertently. Where and how do I drain it ?
way2roll
Wilmington NC
Posted: 10/07/21 06:55am Link  |  Quote  |  Print  |  Notify Moderator
FW tank drain
wing_zealot
East of the Mississippi
Posted: 10/07/21 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Those gauges are notorious for not being accurate.
Lynnmor
Red Lion
Posted: 10/07/21 07:41am Link  |  Quote  |  Print  |  Notify Moderator
The check valve in your water pump may have a leak and is slowly filling the tank.
Cummins12V98
on the road
Posted: 10/07/21 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Yep, had water squirting out my overflow once from a bad water pump.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
laknox
Arizona
Posted: 10/07/21 08:56am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
FW tank drain
I'll say that the others have probably nailed it with cr@ppy gauges and/or leaky check valve in the pump.
Interesting how Keystone totally cheaped out on these and simply put a cap on the end of the Pex instead of a factory-installed valve. My '04 Komfort used a 1.25" drain line with a blade valve and my current KZ has a standard Pex line with a 1/4 turn valve on the end, like the low point drains. Wish my KZ had the 1.25" drain line, that's for sure.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
Super_Dave
Harrisville, UT
Posted: 10/07/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Or the dealer may have put water in the tank to do a systems test before you took delivery.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
 > Fresh water tank
