RV.Net Open Roads Forum: Class C Motorhomes: Does it matter?
 > Does it matter?
Snomas
Sedona, AZ
Posted: 10/07/21 01:41am Link  |  Quote  |  Print  |  Notify Moderator
Does it matter if I get my 2006 Winnebago 29H alignment before I put on sway bars or should I wait?
I get a little wander above 50 mph. I do have a steering arm already installed!
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
Diamond c
West ky
Posted: 10/07/21 04:28am Link  |  Quote  |  Print  |  Notify Moderator
I would wait till I had everything done that I was going to do to the front end, then align it last.
Snomas
Sedona, AZ
Posted: 10/07/21 05:04am Link  |  Quote  |  Print  |  Notify Moderator
That’s my thought also, thx for the input,
DougE
New Braunfels, Texas USA
Posted: 10/07/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Sway bar doesn't impact alignment and may help sway issue slightly. Guess you replaced idler arm (steering arm?) due to wear? Have your alignment shop set the caster close to the maximum spec.
Currently Between RVs
wolfe10
Posted: 10/07/21 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
All good advice.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
pianotuna
Regina, SK, Canada
Posted: 10/07/21 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Alignment is last in the chain.
Regards, Don
Posted: 10/07/21 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Doesn't matter. Sway bar does not and cannot affect steering alignment.
2017 Heartland Torque T29
Snomas
Sedona, AZ
Posted: 10/08/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
wolfe10 wrote:
All good advice.
I thought It was the camber +5 degrees that would heal the wander problem?
Posted: 10/08/21 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Snomas wrote:
wolfe10 wrote:
All good advice.
Nope camber should be 000.
DougE
Posted: 10/08/21 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Camber is more important to get even tire wear across the tread. Caster is what keeps the wheels on shopping carts tracking straight ahead. (They have no camber.)
 > Does it matter?
