IN my 12 years full time I sometimes used digester products if I was goign to be a long time between dumps. but frankly I do not think they helped
Just flush well when you dump. and do not overflow.
Michelle.S
Western NY till fall, then Sebring, FL
I went thru one container of Happy Camper and it didn't make me any happier, just removed a little weight from my purse. Now just use some Calgon Liquid Water Softener, some Dollar Store Pine Sol and water.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
AllegroD
Outdare
Water!
frankwp
Calgary, AB, Canada
valhalla360 wrote: Pro: Makes you feel like you are doing something.
Cons: It costs money and doesn't accomplish anything.
Just use plenty of water and the tank will be fine. It's a holding tank not a digester and there are plenty of microbes in your natural deposits to digest the poo anyway.
This. At the end of the season I do pour a few cups of laundry detergent in tank, fill it half way with water, drive a couple hundred KMs & then dump. That really cleans the tank & ensures that there is no poop build up.
I've tried at least a dozen different brands & none using beats lots of plain old water.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
AJR
Close to Madison Wisconsin
I have found that if you drive a hundred miles or so and then flush the tank. I see very few solids passing through.
Now I do add Dawn to the tank and Calgon if I can find it after a dump & the toilet does use a fair amount of the fresh water each flush. Plus the bathroom sink drains into the black tank.
Works for me.
2014 Leprechaun 290QB
Chevy 4500 6.0
2015 GMC Terrain AWD
