RV.Net Open Roads Forum: Truck Campers: Need your help, ideas
 > Need your help, ideas
woodworker414
Crystal City,Mo.
Posted: 10/07/21 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Good afternoon. We have a Silverado 3500HD, duals, 4x4. Kinda a high step up to the running board for Brenda. Not so much for me. Brenda is of short Stature. Well early this summer Brenda was diagnosed with Rheumatoid Arthritis. Stepping up to the running board is bit harder now. I came up with the idea of maybe adding a second step to the running board. 2 steps up into the truck. Any thoughts, help, ideas would be greatly appreciated.
Brenda and Bill
2020 Lance 1172, our traveling rig
2013 Heartland Landmark Mesa, 40', fifth wheel, we keep at our snowbird home in central FL, Bushnell, FL.
2014 Chevy Silverado LTZ 3500HD, CC, 4x4, LB, duals, DuraMax
bighatnohorse
Gig Harbor - Cave Creek
Posted: 10/07/21 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
We carry a small folding step in the Jeep for our now older friends.
And we use the same folding step for the camper when the first step is more than a single step.
You'd have to pick it up after each time she gets in the truck.
https://www.campingworld.com/e-z-foldz-f........-step-stool-12quot%3B---black-67053.html
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
woodworker414
Crystal City,Mo.
Posted: 10/07/21 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
bighatnohorse, thanks for the reply We have used a folding stool like the one you gave the link to I guess we will be using it more often now. Have to put some kind of string, strap on it so Brenda can pick it up when she is in the truck alone. And to be able to lower it to the ground when she wants to get out of the truck.
Posted: 10/07/21 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
Not a cheap option, but Amp Powerstep XL's deploy at like 13" lower than the door sill.
2017 Heartland Torque T29
#1Flyboy
California
Posted: 10/07/21 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Amazon has some other options!
woodworker414
Crystal City,Mo.
Posted: 10/07/21 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
#1Flyboy, thanks for the reply. I will check it out.
jimh425
Western MT
Posted: 10/07/21 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Some of the auto fold down steps are pretty low. You might check those out.
TxGearhead
Posted: 10/07/21 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
We just use a cheap one step plastic stool. Keep on the back seat with a towel under it.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
notsobigjoe
southeast
Posted: 10/07/21 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hello OP. I went to amazon and typed in running board steps and many pages came up.. Mostly new running boards but there were a couple of attach to the existing running board option. You'll have to scroll through the pages to see them. I scrolled to page 6 and saw three or four options. Good luck. Joe
AnEv942
CA
Posted: 10/07/21 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
We also used the EZ step for few years. The 12" height made it much easier for Margaret to get in. The retrieval not so much, I'd just wait for her to get in the pick up the step and store behind my seat. On unlevel ground you need to pay attention, especially getting out...
I might suggest what we finally did, but its not an inexpensive solution. Installed Amp-Research power running boards. When deployed they split the distance and fold out lower than most fixed running boards. Top of step height when out is 12", tread is about 6" wide so very secure. Our door sill is ~28". Standing on step you can almost fall in. Even my 90 year old mom is able to get in.
I installed so saved a bit but to Margaret they are worth every penny.
Our camper projects page
