RV.Net Open Roads Forum: Tech Issues: Propane fridge ticking when turned off
 > Propane fridge ticking when turned off
swimmer_spe
Sudbury, Ontario, Canada
Posted: 10/07/21 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
Walking by my RV today, I heard a ticking coming from the back of the fridge. The propane has been turned off, as well as the knob inside has been turned to off for a few weeks.
The fridge is a Dometic Americana 2 way fridge.
Why is it clicking if it is in the off position?
How do I fix it?
BobsYourUncle
Calgary Alberta Canada
Posted: 10/08/21 07:04am Link  |  Quote  |  Print  |  Notify Moderator
First thing that comes to my mind about a fridge and ticking is the DSI igniter. But turned off it should not be doing that. And even if it were on, and propane off it won't keep going. It would cycle off and show the check light.
I suggest taking the cover off the outside and try to find the location of the ticking. If it is hard to determine even then, get a length of flexible plastic tube a couple feet long. Stick one end in your ear and point the other end into the back of the fridge, fishing around to find the sound. When you are close, the sound will amplify in your ear.
That's how I used to find vague strange noises, whistles etc in car engines. Works well!
Once you ID the sound source, then you can figure out why.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
ReneeG
Meridian, Idaho
Posted: 10/08/21 07:47am Link  |  Quote  |  Print  |  Notify Moderator
I'd double check that it is really OFF at the fridge. Ours if on either the gas or electric setting and the gas is off and the power options are off, will continue to "tick", trying to light.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
CharlesinGA
South of Atlanta, Georgia
Posted: 10/08/21 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Pull the 12v DC fuse that operates the fridge, see if it stops.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously 2008 Thor/Dutchman Freedom Spirit 180. SOLD - 2007 Winnebago View 23H Motorhome.
