RV.Net Open Roads Forum: PSA - cracked wheel on 2012 F53
Open Roads Forum  >  Class A Motorhomes  >  Safety Issues & Recalls
 > PSA - cracked wheel on 2012 F53
WoodIsGood
Calif.
Posted: 10/08/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
While doing a lugnut torque check I discovered a crack in the hub-plate of a rear wheel. The wheel has been replaced and the rest of my wheels checked for cracks. I filed a report with the NHTSA. Glad I didn't find it the hard way as the wheel failed!
* This post was last edited 10/09/21 04:17pm by WoodIsGood *   View edit history
Chum lee
Albuquerque, NM
Posted: 10/08/21 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Good find! Rare in the hub of steel wheels , . . . . but, . . . . it does happen. Did the crack clearly propagate to the other side?
Chum lee
WoodIsGood
Calif.
Posted: 10/08/21 10:06am Link  |  Quote  |  Print  |  Notify Moderator
The crack does go all the way through, but is only about 1-1/4" long on the back side. A band of rust on the powder-coat is what caught my eye.
Chum lee
Albuquerque, NM
Posted: 10/08/21 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Good eyes! It's not a Ford part number, but, my bet is that the stamping of that post production/serial number (whatever it is) on the face of the flange had something to do with the initiation of the crack. Glad you found it before the . . . . . "unthinkable" happens. The engineers at Ford should get to the bottom of this before "ASAP" happens. Hopefully it's just an exception rather than a pattern failure.
Chum lee
Near DVNP, California
Posted: 10/08/21 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
You are…we are…lucky!
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Posted: 10/08/21 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Chum lee
I could tell you what I think of Ford.. but well. (Not nice)
Remember the old ford Explorer Roll-a-matic.. They blamed Firestone.
Well the cause was low tire pressure. BY DESIGN.
To get a softer ride they said run the tire 5PSI below what Firestone specced.
Now new tires don't leak (much) so the owner has been a bit lax on checking tire pressure.. he's not 5 PSI low. he's 5 PSI period. first pot hole the rim slices the sidewall like hot butter and Mr. Point and Shoot driver stands on the brakes with both feet. A very bad idea.
Flippitty flipptey time.
Bruce Brown
Northern NY
Posted: 10/08/21 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Any chance you could repost the picture, I can get it to open.
Thank you.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
WoodIsGood
Calif.
Posted: 10/08/21 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Tried posting an image with the part number of the wheel, but can't seem to get it to work.
Bruce Brown, not sure why you can't see the picture. I resized it to make it smaller; maybe that will help?
Chum lee
Albuquerque, NM
Posted: 10/08/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
Nice pic, (thank you) but I need to see the "other side" of the hub.
Chum lee
Bruce Brown
Northern NY
Posted: 10/10/21 05:06am Link  |  Quote  |  Print  |  Notify Moderator
Got it - thank you!
