RV.Net Open Roads Forum: Class A Motorhomes: New motor home blues…
 > New motor home blues…
Lantley
Ellicott City, Maryland
Posted: 10/22/21 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Try to keep athe glass is 1/2 full perspective.
Wires up against the exhaust is a simple fix.
While I understand your aggravation as long as the fix is simple take care of it and move on. Its when the fixes are not so simple that the real problems begin! Hopefully the entire rig will be sorted out before long and you can forget about all your new RV blues.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Bruce Brown
Northern NY
Posted: 10/22/21 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Alex and Tee wrote:
La Mesa tech came out and found TWO lines to the front right jack melted from being up against the exhaust system. It seems people either have no brains or take no pride in workmanship.
Or both...
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
dodge guy
Bartlett IL
Posted: 10/22/21 09:45am Link  |  Quote  |  Print  |  Notify Moderator
So much for Tiffin quality!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
way2roll
Wilmington NC
Posted: 10/22/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Curious if this is a result of Thor buying Tiffin or COVID or both. We may never know. Wonder if any other new Tiffin owners are having issues.
Alex and Tee
Jacksonville , FL
Posted: 10/24/21 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Can I not catch a freakin' break here???
Now I have a pin hole leak in the Truma Hot Water heater!!!
Arrgghhhhh!!!!
Alex & Teresa
2022 Allegro Open Road
2021 Colorado 4x4
Bruce Brown
Northern NY
Posted: 10/24/21 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
Your Tiffin sounds like my parents was - it never anything big but it was always something!
Good luck, hopefully yours gets ironed out.
olfarmer
Iowa
Posted: 10/25/21 06:15am Link  |  Quote  |  Print  |  Notify Moderator
I understand your frustration! Surely the water heater is under warranty? Sounds like it all should have been except the gen set oil change.
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
Alex and Tee
Jacksonville , FL
Posted: 10/25/21 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Yes it is all warranty repairs but it has caused much disruption to our plans of visiting family and friends before our relocation to Phoenix and loss of hundreds of dollars of prepaid park stays that have had to be canceled last minute due to having to stay within proximity of our dealers mobile tech service radius.
olfarmer
Iowa
Posted: 10/26/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
I certainly understand that. They should reimburse you for your expenses but I am sure they will not do that. It seems like I hear of a lot of new motor homes that cause a lot of problems!
Alex and Tee
Jacksonville , FL
Posted: 10/26/21 11:49am Link  |  Quote  |  Print  |  Notify Moderator
We had the mobile techs out first thing this morning. They fixed the leak in the Truma Aqua Hot (something loose and just required tightening), they removed the two hydraulic hoses and had new ones made at a local shop. Were back, installed, system bled and tested all before lunch. Kudos to the LaMesa service team!!
