RV.Net Open Roads Forum: Class A Motorhomes: Head lights/ running lights switch
 > Head lights/ running lights switch
Thomcat
Calgary, Alberta, Canada
Posted: 10/09/21 09:35am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2006 Fleetwood American Tradition Model Z. It's on a Spartan Chassis. The headlight/running light switch is the rocker variety that half way gets the running lights going and all the way turns the headlights on too. The switch will not turn off the running lights after use. We put a meter the switch and determined that the first notch isn't disengaging and the only way to turn off the running lights after use is to pull the fuse. It then resets to off. We tried brake clean and blowing air through it and it made no difference. The problem is finding a replacement switch. We've been looking around locally and no one has been very helpful. If anyone has any idea on where to find one I'd be most appreciative.
Regards;
Thom.
Thomcat from C eh N eh D eh
jdc1
Rescue, Ca
Posted: 10/09/21 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Electronics supply store. They should sell about 200 varieties of switches. If you need to, you can break it down and install a second switch, one for regular headlights, the second for brights.
enblethen
Moses Lake, WA
Posted: 10/09/21 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Remove switch to a point that you can read numbers and other infromation
Post what you find.
JR products is a good source for many switches
search Fleetwood website for your coaches wiring diagrams. They should show switch part number.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
enblethen
Moses Lake, WA
Posted: 10/09/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Here is link to some off/on/on switches.
Newark
larry cad
ohio
Posted: 10/10/21 03:35am Link  |  Quote  |  Print  |  Notify Moderator
Does your switch look anything like this?
This is a typical "Carling Switch" There are hundreds of them. Get the part number off of yours and contact the factory to get a source.
Our Travel Blog
Thomcat
Posted: 10/10/21 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Very similar, my tech tells me that the part number comes up obsolete. I'll get the number and search myself. Thank you
