RV.Net Open Roads Forum: Tech Issues: Battery Issue?
 > Battery Issue?
DD716TED
Washington State
Posted: 10/09/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
We are camping and I noticed something that I had never noticed in the 11 years we have owned the trailer.. We are plugged into pedestal power. When nothing that requires 12 volts is on, the 12v power monitor meter reads 13.7 volts dc.. However when the refrigerator is on (not on gas), the dc power drops to 12.6 vdc AND when the furnace cycles on with refrigerator on, lights dim and 12 v power monitor meter drops to 11.7 volts dc.. Don't ever remember seeing this in the past..ARE MY BATTERYS FAILING? Help please.. easier to find new batteries on Saturday than Sunday when camping..
Owens River area
Posted: 10/09/21 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Could be. Have them tested IMO. How old are the batteries? 11 years is a great life for a wet battery.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
BFL13
Victoria, BC
Posted: 10/09/21 10:38am Link  |  Quote  |  Print  |  Notify Moderator
It appears the converter is is working to supply that 13.7 to the monitor somehow, but that the fridge and furnace are on battery.
Something is blown so the converter's 13.7v is not reaching the fridge and furnace and also note the battery is getting lower with use, as indicated by the voltage drop when the furnace comes on.
You can keep going that way until the battery bank gets too low and then you will need a battery charger, or else get the converter back on line.
You don't need new batteries now, just a battery charger.
BTW the fridge on 120v does use a little 12v for its controls
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
DD716TED
Washington State
Posted: 10/09/21 10:50am Link  |  Quote  |  Print  |  Notify Moderator
DD716TED
Washington State
Posted: 10/09/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
when pedestal power is disconnected, fridge still works and furnace still runs.. but for how long?? didn't want to find out..
BFL13
Victoria, BC
Posted: 10/09/21 11:13am Link  |  Quote  |  Print  |  Notify Moderator
To be sure they will not get so low that you can't run 12v things, you need to recharge the batts. They are low now, so you could get a simple auto battery charger today and leave it clamped on the batts since you have 120v to run it.
If you got new batts today, they will just get run down too with no battery charging. You could get new batts and a battery charger. Depends how old the batts are in there now.
You need a working battery for the trailer when it is on the road in case of a breakaway.
I am confused about the 12v monitor showing that 13.7v and then also showing the lower figures when 12v loads come on.
IB853347201
Eastern Ontario
Posted: 10/09/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
How old are your batteries? From what you describe, I would say they are toast.
2010 Suncruiser
CA Traveler
The Western States
Posted: 10/09/21 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
First step is free battery load test at most auto stores.
2014 Grand Cherokee Overland
Bob
lenr
Indianapolis, IN
Posted: 10/09/21 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
It's hard to tell the difference between battery problems and charger problems. Because RV converters (chargers) are strong enough to run the trailer when the battery is discharged, my bet is on the charger especially if it is a WFCO. Progressive Dynamics makes a great converter for replacement when using lead acid batteries.
lenr
Indianapolis, IN
Posted: 10/09/21 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Oh, and bad converters have been known to boil out batteries ruining them--so, both converter and battery could be bad.
 > Battery Issue?
