RV.Net Open Roads Forum: Truck Campers: DC-DC Charger Wiring Input Suggestions
 > DC-DC Charger Wiring Input Suggestions
moonlitsouls
Everywhere
Posted: 10/09/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Hope all is well, I’ve attached a diagram to my truck camper , I’m going to use Anderson connections to create a detachable connection for the wires from the starter battery to the charger. Where do you guys think I should route the wire ? What’s the best way to come into the camper? Thanks a lot
* Adjusted image width to 640
* This post was edited 10/10/21 09:24pm by an administrator/moderator *
c.traveler2
Moreno Valley,Ca.
Posted: 10/09/21 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
I ran my 4gauge/Anderson connection near the same place that the camper plug is at.
2007 F-250 4x4 /6.0 PSD/ext cab/ 2020 Bunduvry
Lance 815/ 85 watts solar panel (sold)
2020 Bunduvry by BundutecUSA
Travelingman2 Photo Website
Truck Camper Trip Reports 3.0
travelingman21000 YouTube Videos
Alex and Julie's Travels Blog
Bradymydog
Western MA
Posted: 10/10/21 05:45am Link  |  Quote  |  Print  |  Notify Moderator
Living in the NE with all the salt on the road, I did not use Anderson plugs when I wired my DC-DC charger as there was no way to adequately weather seal the connectors or cable penetrations when not connected. I installed two Pollak 2 pole recepticals, one on the camper and one in the bed of the truck. Each is weather sealed and I don't have any pigtail to worry about when the camper is off the truck which is most of the time in my case. I then made a connector cable with the female connectors on each end. Works great for me, but not the least expensive solution.
I also looked into trolling motor connectors but wanted something with a higher amp rating.
https://www.etrailer.com/Wiring/Pollak/PK12801.html?feed=npn&utm_source=google&utm_medium=cpc&utm_campaign=Google%20%7C%20Shop%20-%20Wiring&adgroupid=84618835800&campaignid=1672412098&creative=394587238933&device=c&devicemodel=&feeditemid=&keyword=&loc_interest_ms=&loc_physical_ms=9001738&matchtype=&network=g&placement=&position=&gclid=Cj0KCQjwnoqLBhD4ARIsAL5JedInXyn3TtLtTAXS013RVl9eO0mH-XMJQtjQJLEBR7yN215etQmDhbMaAsxnEALw_wcB
theoldwizard1
SE MI
Posted: 10/10/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
If you have the Power Pole connectors use them. Periodically clean grease the contacts.
Kayteg1
California > Nevada
Posted: 10/10/21 09:25am Link  |  Quote  |  Print  |  Notify Moderator
I see pictures of carport, but no wire diagram?
Why are you using B2B charger? Do you have lithium battery?
On my Ford I was having idea of using on-board inverter to run 120V inside and use camper converter for faster charging where the small trailer wire was not adequate. But that was never important enough to me and sold the truck before doing it.
time2roll
Posted: 10/10/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
I would use the existing charge wire and place the DC-DC charger near the battery in the TC.
20 amp rating should be sufficient.
675w Solar pictures back up
Kayteg1
California > Nevada
Posted: 10/10/21 11:36am Link  |  Quote  |  Print  |  Notify Moderator
I think Ford has 30 amp breaker on its charge circuit, yet had a situation when deeply discharged 2 camper batteries would keep cycling the breaker and after 3 or 4 hr of driving/charging the batteries were still low.
The situation repeated when I got shore power as 40 amp converter was cycling as well and it wasn't till next late morning when finally the charge stabilize.
I researched B2B chargers for my boat project, where I add "house" batteries and have 30 amp alternator. I was hoping B2B could limit amperage to preset value, what happen to be illusion.
I finally ended with battery combiner and 20 amp automatic breaker.
All that with voltage meter on the cluster, so I will not get surprised the same way I was in the camper.
time2roll
Posted: 10/10/21 11:48am Link  |  Quote  |  Print  |  Notify Moderator
OK that self resetting breaker is in the TC right? These self resetting breakers are a disaster waiting to happen. Get a real breaker such as Bussmann Hi-Amp of the correct rating (amazon). Probably 40-50 amp is appropriate depending on the wire size and other charging equipment.
Kayteg1
California > Nevada
Posted: 10/10/21 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
The truck charging circuit had to have circuit breaker somewhere in fuse box.
I never really check it as it was always resetting itself eventually.
Converter doesn't have any visible circuit breaker, so it could be overheating sensor who was shutting it off.
I don't know how protection breakers can lead into disaster?
Putting 40-50 amp breaker on 30 amp wire might.
moonlitsouls
Everywhere
Posted: 10/10/21 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
hey guys , im using a renogy 60a dc-dc charger , and i upgraded the stock altn to 250amps , im going to put the dc-dc charger right near my existing battery bank , the part im confused about is where to mount the anderson cable to make this as simple as possible , my camper stays on the truck 95% of the time so im not too worried about water and stuff. maybe i can drill a hole in the battery bank compartment door and just leave them plugged up inside there , theres room for it
