RV.Net Open Roads Forum: Class C Motorhomes: Replacing water heater due to age........
 > Replacing water heater due to age........
VA-Apraisr
glen allen, VA
Posted: 10/09/21 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, was at the beach last week and one of my friends suggested I should change out my Atwood 6-gal. water heater since it is 17 years old. It's working just fine, but, he feels it could be deteriorating on the inside and could start leaking/flooding the RV. Seems replacement is $375-$475 so not a lot of cost. Obviously, anything can wear out and start leaking, but, wondering if anyone has done this simply due to the age of the unit?
PartyOf Five
Wheaton, IL
Posted: 10/09/21 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
2001 still going strong thankfully.
PartyOf5 appreciating our Creator thru the creation. 5 yrs, 50k
May you find Peace in all you endeavor.
Mel Stuplich
Wausau, WI
Posted: 10/09/21 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
A wise man once told me: "If it ain't broke DON'T FIX IT"
bobndot
Posted: 10/09/21 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
If its an Atwood its aluminum and they last a long time.
I always have bad luck with inexpensive electronics and replace the boards so i dont get stuck while off grid.
I usually replace the OEM circuit boards in my rv appliances using Dinosaur boards which are very reliable. Keep the OEM board as a spare , just in case.
DrewE
Vermont
Posted: 10/09/21 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't replace a perfectly working water heater just because it's almost old enough to vote, either in an RV or a house. I do think it wise to turn off the water pump or campground spigot when away from the RV to prevent flooding in the event of a leak somewhere in the system.
larry cad
ohio
Posted: 10/10/21 03:25am Link  |  Quote  |  Print  |  Notify Moderator
21 year old Atwood in my motorhome working fine.
Our Travel Blog
toedtoes
California
Posted: 10/10/21 06:20am Link  |  Quote  |  Print  |  Notify Moderator
I agree that replacing it when it is working fine is not necessary.
My 1998 trailer has the original water heater and has had no problems.That's 23 years. My 1975 clipper had a new water heater installed at some point in its 46 year old lifetime. I don't expect to have to do so during my ownership.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
VA-Apraisr
glen allen, VA
Posted: 10/10/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies!!......yes, always have water pump OFF and rarely in a campground. Never hurts to verify with the RV elite on this site (always appreciated!!).
Chum lee
Albuquerque, NM
Posted: 10/10/21 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Yep! Me too. I have a 21 year old 6 gallon gas/electric Atwood in mine and it's still working fine. All I've ever done is regularly clean the flue/burner/ignitor. IMO, the water heater is probably the most reliable appliance in my Class A. (so far)
That said, I've seen a lot of aging RV's with carbon/soot/burn marks up the exterior panel right over the water heater cover. Don't ignore regular maintenance especially if the heater is having trouble lighting or staying lit.
Chum lee
LittleBill
Scranton, PA USA
Posted: 10/10/21 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
2000 atwood here. use it all the time. i drain it every trip, 0 crud
